Axtell oil bypass system
Changing out multiple parts is great "process of elimination", that is fantastic but can we isolate it? The question is changing what specific part does the most in eliminating noise or in this case add better oiling. Replacing one specific part is a more efficient way to go for now, agree?
Also noted many have replaced lifters this alone can be a huge difference in oiling the top end where many have suggested is the main location of engine noise occurs. Cam chain noise is another, but believe that is contributing but not the main culprit. (below is description of part & price)
DETAILS
This is a new product designed and developed by the Axtell Mountain Motor team. This bypass valve consists of a precision-machined “needle and seat” that inserts in place of the factory oil pressure relief valve located within the Twin CamŽ cam plate. With the factory OEM oiling system configuration, when oil pressure becomes excessive, it is bypassed from the high pressure side of the feed gerotor back to the low pressure side, “looping” the oil in the feed gerotor gears (see B and C in diagram). This causes the introduction of air into the pressurized oil (aeration) - aerated oil is foamy and spongy, and results in lower oil pressure and volume. When this occurs, the entire oiling system if affected - engine heat and noise builds, piston oilers shut down sooner than designed, valve train and top end life is shortened. This system blocks the factory port back to the feed side of the pump and directs the bypassed oil into the cam chest. The scavenge side of the oil pump returns the excess oil to the oil tank and eliminates the oil “looping” and its negative effects.
They claim Axtell valve, you can expect higher, more stable oil pressure at all engine rpms, longer oil life due to reduced oil shear, lower oil and engine temperature, improved valve train control and reduced noise. Zipper’s recommends this for use with our Red ShiftŽ Dual Piston Cam Chain Tensioners. Models available for all H-DŽ and Screamin' EagleŽ brand cam plates. Patent Pending #61/693,612
#620-103 Axtell Bypass Valve for All Harley-DavidsonŽ and Screamin' EagleŽ Brand Twin CamŽ Cam Plates +$84.99
B Bop
2012 FLHR (Road King) Ember Red Sunglo & Merlo
Cruise Control, ABS, Chrome Aluminum Profile Laced Spoke Tubeless Wheels, Security Package, Saddle Bag LED Lid Spoilers, and an array of accessories that enhances nostalgic appearance & blood curdling performance.
Do not argue with an idiot. He will drag you down to his level and beat you with experience.
but it do see some foamy oil and ...unless I have the oil level at the bottom ... I get a dribble out of the oil stick ....not much but damnit I just cleaned it every time lol
I then installed Rock outs. I don't think they helped much on this bike but i didn't see very pronounced witness marks from the rocker shafts rocking against the mounting bolts.
Last winter I installed the Red Shift dual piston chain tensioners and the Axtel oil bypass spring. The bike has never been so quiet. The valve train sounds so much better and quieter. So far over the coarse of this summer it's run smooth and trouble free. It definitely boosts up the oil pressure at idol and going down the road.
Sent from my iPad using IB AutoGroup
