Is a tune needed
Old Feb 6, 2013 | 08:41 PM
Road King Man's Avatar
Road King Man
Default Is a tune needed
If I install my Vance Hines dresser duals with my stock mufflers and stock intake on my 2012 FLHRC, can I run like this without a tune until if figure out what slip ons I want?
Old Feb 6, 2013 | 08:44 PM
Sagido's Avatar
Sagido
I would wait to get it all done at once. I know it is tough to leave them sit in the box.
Old Feb 6, 2013 | 09:25 PM
fat daddy's Avatar
fat daddy
Yeah it won't hurt a thing
Old Feb 6, 2013 | 09:30 PM
rooti's Avatar
rooti
no problems....ride on
Old Feb 6, 2013 | 09:44 PM
SunCruise's Avatar
SunCruise
Your stock mufflers are different (left/right)to go along with stock header 2-1-2
Changing to "True Duals" 2-2 header would require matched mufflers No??
With each cylinder being independent, I wouldn't put two different muffs on.
I could be wrong but look inside your stock muffs...they are not the same.
With the proper muff on a 2-2 header and STOCK AC you "may" be able to allow the ecm to make its own small adjustment to the tune but I'm not sure of that as I had already done a stage 1 before I added the true duals on mine.
SC
Old Feb 6, 2013 | 10:01 PM
Oldman Harley's Avatar
Oldman Harley
To answer your question No you do not need a tune if that is all you will be doing.
Tim
Old Feb 6, 2013 | 10:59 PM
the warden's Avatar
the warden
Should be fine. I see nothing in the "12 service manual to suggest the mufflers are any different so going from a 2-1-2 to a 2-2 should not be a problem. If it were me though, I would wait and do it all at once. it will save you some time and money. You will need to replace the muffler clamps each time you remove them as they are a one time use item. Once they are tightened they should not be used again. While I have done so on occasion and got away with it, on others I have not and wound up with an exhaust leak.
its59er
VRSC Models
Nov 14, 2018 12:12 AM
jclax01
Oct 5, 2015 09:55 PM
68beep
Mar 4, 2014 06:10 PM
dafuzz89
Exhaust System Topics
Jun 14, 2013 09:20 PM
HD101st
Apr 17, 2010 04:28 AM
