se adjustable pushrods
Old Feb 9, 2007 | 01:31 PM
wesd41's Avatar
wesd41
Default RE: se adjustable pushrods
ORIGINAL: rollover
Are you still able to use the stock pushrod tubes with the adjustables or do I need to purchase different tubes with the rods?
Stock tubes are fine.
And after reading about people's locknuts coming loose, maybe cutting the ez rods out wasn't so bad after all. Beats rebuilding a motor.
Old Feb 9, 2007 | 02:28 PM
cjuetten's Avatar
cjuetten
Don't know of any part that has never failed, but the adjustable pushrods are as reliable as anyother parts in your motor.
IMHO:
The odds of a top end leak after a cam install without adjustable pushrods are10 fold greater than the odds of anadjustablepushrods failure.
Old Feb 9, 2007 | 02:34 PM
xxxflhrci's Avatar
xxxflhrci
ORIGINAL:
IMHO:
I'll agree with that....
Old Feb 9, 2007 | 02:53 PM
rollover's Avatar
rollover
ORIGINAL: cjuetten
IMHO:
Even when using the stock gaskets?
Old Feb 9, 2007 | 02:59 PM
xxxflhrci's Avatar
xxxflhrci
ORIGINAL: rollover
ORIGINAL: cjuetten
IMHO:
He's talking about rockerbox gaskets, not head gaskets.
In reality, there are way more things to go wrong when you take off the rocker boxes vs. just cutting out the stock rods. You are disassembling more things, replacing more gaskets, and will need to do a little more technical work to put the rocker arms back in correctly. Even though I had my adjustable mishap, I would still go with adjustables for a cam swap over pulling the rocker boxes. I have done both. The adjustables are far easier.
Old Feb 9, 2007 | 07:05 PM
Johnny Law's Avatar
Johnny Law
Very easy job. Directions are easy to follow. I put a set on my 2001 RKC when I installed new cam chain tensioners.
JL
wagsrk08
Dec 15, 2018 12:15 PM
kryingame
Dec 16, 2013 05:41 AM
2BIT
Sep 11, 2012 04:15 PM
VTGlideRider
Dec 24, 2010 04:21 PM
hmmr
Jan 16, 2008 06:51 AM
