single side brake??
Old Feb 9, 2013 | 12:57 PM
stupid_rope's Avatar
stupid_rope
im happy with mine. 6 piston and 13" floater. i stop, just not as fast as i did with duals.
im certainly not changing back. if i did, i would put another chrome 6 piston on the right side and have (2) six piston with (2) 13" rotors...which would probably allow me to do stoppies lol
Old Feb 9, 2013 | 01:00 PM
Uncle Larry's Avatar
Uncle Larry
Physics dictates that the 13" rotor will exert more stopping power than a smaller diameter rotor by the means of "increased leverage" on the point of axis ... think about it .... spin a wheel and try to stop it by grabbing the wheel near the axle area or further out near the tire ... and as far a a caliper "breaking in" ... I've never heard, or seen, or encountered anything regarding this ... I've been an ASE mechanic ( now retired ) for more years than I care to remember ... It just doesn't make any sense ... hydraulic forces don't become greater or more effective as time/miles go by.
Old Feb 9, 2013 | 03:15 PM
NMNSG08's Avatar
NMNSG08
If going single ,go with a 13" rotor and use the glenndyne caliper.I know people with this set up and some say it is more than enough braking power.I have the jay brake 6 piston and i am going to try the glenndyne.
Old Feb 9, 2013 | 03:28 PM
jmorganroadglide's Avatar
jmorganroadglide
Big Kahuna HDF Member
I have a single rotor with ABS. If the front brake will easily engage the ABS system, is this not as much stopping power as a dual rotor with the ABS engaged?
Old Feb 9, 2013 | 03:45 PM
Gigawitz's Avatar
Gigawitz
Exactly, sigle disk is plenty of stopping power for normal riding conditions.. Everything is a trade off, the extra rotating mass of the additional disk is a performance decrease under normal conditions.
You will only take advantage of a dual disk setup if you are braking at very high speed. The additional disk will spread the braking heat and avoid the brake fluid boiling in the caliper causing brake fade..
I have single 11.5" rotor with a 4 piston on my softail and it will lock the front causing it to bounce if i squeeze hard enough at under 80MPH... This is more than enough for "normal" riding conditions.. I would notice dual disk if I was trying to panic stop at 115MPH but how often does that happen?
Dual disk is way overrated by people that don't even use it IMO....
Single disk is a performance advantage because of less rotating mass, unless you are racing...
So, single disk looks better, it performs better at a reasonable speed, leave dual disk for the high speed race bikes..
I removed the right disk from my FXRS and it looks better, lost weight (rotating mass) , and performs the same at normal speed..
Been riding over 30 years and tried it all, dual disk is way overrated IMO...
Added to the irony of this, how much brake do you really need to exceed the contact patch of a skinny 21" front tire? Seroiusly, I have since upgraded the front tire on my bike to a 18 X 130 tire and my single disk will lock it any time I want...
For cruising (not racing) ,Dual disk is a psychological advantage at best ...
Old Feb 9, 2013 | 05:09 PM
sgdiesel's Avatar
sgdiesel
That is an excellent observation / question.
At a most simplistic level the answer is Yes, you are right.
At a more detailed level (and assuming the HD ABS system does exactly what it should do as I am sure many will now chime in and take this off on a tangent) it is key to understand that ABS is actually concerned with traction control.
Why is this statement relevant? This is easiest described by considering extremes. Clearly if you were riding on ice then it takes the smallest of braking efforts to trigger the ABS. You could therefore use your argument to justify putting bicycle brakes on a bagger!
As we increase the level of traction to a point where we are braking on Tarmac that is firm, gravel free and no potholes it is possible that you will not trigger the AbS.
Assuming for now that, even in these ideal conditions, you can trigger ABS it will be as a result of you having to pull twice as hard on the brake lever (assuming a linear relationship between lever force and brake hydraulic pressure).
Given that the system pressure is now twice the pressure of the dual rotor system I would not want to hazard a guess at how well the ABS modulation will work. Personally, from my experience of designing closed loop hydraulic control systems, that is a risk I would not even begin to contemplate, especially as the time I am going to really test it in anger I probably won't get a second chance if it doesn't work!
Old Feb 9, 2013 | 05:42 PM
jmorganroadglide
I have a six piston caliper with a larger rotor and it will easily engage the ABS. So other than heat dispensation, I can't see much of a downside.
Old Feb 9, 2013 | 05:45 PM
Gigawitz's Avatar
Gigawitz
So, by pulling twice as hard on the brake lever to get the same result, it proves the brakes are adequate but at a loss of detail... I can agree that dual disk might provide more accurate perception of pressure applied to the lever but an experienced rider could accomplish the same task with a single disk..
I guess the point is, single disk will still stop you if you have the skills to use the system but duals are better for the average rider unfamiliar with the proper pressure applied to the brake lever...
Or, perhaps I missed the point...
ABS is a dummy system made to override a panic stop by a poor operator.
A skilled pilot has no need for ABS and can regulate brake pressure by feedback from the road...
I can see where dual disks will result in more accurate braking as well as spreading the heat to avoid brake fade. These things really don't matter unless you are braking at speeds well above the norm...
Z
Oct 31, 2021 06:14 PM
BobbyH83
Oct 10, 2016 01:44 PM
catfish24
Wheels/Tires
Oct 12, 2009 04:15 PM
07_Bagger
Wheels/Tires
Jun 25, 2009 08:43 AM
Warpig
Aug 9, 2006 09:55 AM
