Backoff Brake light modulator.
Old Feb 11, 2013 | 01:03 PM
Bullitt59's Avatar
Bullitt59
Default Backoff Brake light modulator.
I am wondering if anyone has installed this item on their Ultra Classic. Instructions say which wires (but not which colour is which) to attach the red & white wires to, but there are 3 wires going to the brake light. Also, any ideas on where to put the housing?
Attached Thumbnails Backoff Brake light modulator.-1001-20back-20off-20copy-1-.jpg
Old Feb 11, 2013 | 01:23 PM
mikelikesbikes's Avatar
mikelikesbikes
Mighta been better off with a BAL or something like it. The BAL is one Bright *** Light!!!
Old Feb 11, 2013 | 01:25 PM
stevevfd's Avatar
stevevfd
I have http://www.customdynamics.com/motorc...ht_flasher.htm
on my Street Glide and it had plugs on it. It just plugged right into the factory harness.
That one seems more complicated. I found instructions though... good luck!
http://www.customdynamics.com/pdf/wi...structions.pdf
Old Feb 12, 2013 | 07:09 AM
signaldynamics's Avatar
signaldynamics
Stage IV
Default Information from the MFG
@Bullitt59
The 3 wires that you should be seeing most commonly are black(ground), blue(running lights), and red with or without a colored stripe (brake).
If this is the case, the wire you would use is the variation of red.
This is the most common scenario, if you have any further questions or need additional assistance, please call 800-785-1814 | M-F | 9-5 EST.
Signal Dynamics - Technical Support
Old Feb 12, 2013 | 07:57 AM
Moe55's Avatar
Moe55
Mine is hooked up to the lights on the tour pack only. The modulator is under the liner on the left side.
ssathre
Jul 15, 2013 08:50 AM
theoapodaca
Feb 21, 2011 01:15 PM
throttlejunkie
Apr 24, 2009 08:49 AM
dr.jim
Aug 24, 2007 10:53 PM
jhogan20
Apr 20, 2006 12:19 PM
