06 Electra Glide speedo not working
Old Feb 11, 2013 | 05:25 PM
Judas Tree's Avatar
Judas Tree
Stage III
Default 06 Electra Glide speedo not working
The speedo on my 06 EG is not working.....the odometer works (digital) but the speedo dial does not.....Any ideas would be helpful.....also this is my first Electra Glide......Thanks
Old Feb 11, 2013 | 05:55 PM
dawg's Avatar
dawg
Speedometer, connection, or vehicle speed sensor. Usually the sensor makes it act whacky but if the needle doesn't move at all, it might not be the sensor. Process of elimination
Old Feb 11, 2013 | 07:01 PM
Judas Tree's Avatar
Judas Tree
Stage III
Ok thanks.....The weird thing is why does the odometer still work?.....I would think they would work off of the same sensor...
Old Feb 11, 2013 | 07:09 PM
northerndave's Avatar
northerndave
This probably doesn't help but I like to try anyways.
My speedo started freaking out last summer. I found that I had some metal shavings on my sensor.
I wiped it off and it's been perfect ever since.
Old Feb 12, 2013 | 11:43 AM
Judas Tree's Avatar
Judas Tree
Stage III
Thanks guys.....I imagine it is the speedo itself....I checked the sensor and it was clean as a whistle....Thanks a lot for your help.....
Old Feb 12, 2013 | 12:04 PM
Hotrodz_n_Harleyz's Avatar
Hotrodz_n_Harleyz
If it was te sensor, the odometer shouldn't be working either, and also your auto cancel would stop working on your turn signals as well.
Old Jun 7, 2013 | 09:41 AM
dvlgsxr20's Avatar
dvlgsxr20
Do your turn signals work? My speedo went out yesterday and the turn signals stopped working same time.odometer worked also. I found a blown fuse for horn. See if your horn works if not that's the issue. I guess this is common. Works perfectly after replacing fuse. It was also a 2006 electra glide
NickSchoff
EVO
Sep 19, 2023 11:39 AM
19JMan70
Apr 11, 2014 06:03 PM
drs0413
Electrical/Lighting/Alarm
11
May 12, 2012 01:01 PM
hammon
Jun 9, 2008 06:44 PM
emeraldbiker
Aug 14, 2006 10:32 AM
