Kury RTB module
Old Feb 12, 2013 | 06:37 AM
CRocks's Avatar
CRocks
Default Kury RTB module
Wanna put a Kury #4859 RTB module on the 2012 RK + had a couple questions for those of you with them installed. Is it strictly plug + play, do the emer flashers still work, did you have to use equalizers? TIA
Old Feb 12, 2013 | 07:57 AM
CRocks's Avatar
CRocks
Nobody?
Old Feb 12, 2013 | 10:18 AM
harleycharlie1992's Avatar
harleycharlie1992
Unofficial HDF Chaplain
whats an rtb module?
Old Feb 12, 2013 | 10:46 AM
Keithhu's Avatar
Keithhu
Run Turn Brake module
It is plug/play, did you look at the Kury Web site? http://www.kuryakyn.com/Products/868...ake-Controller
The HD one is, thats what I have.
Kury part has the advantage of a pulsing feature that HD does not
Old Feb 12, 2013 | 11:10 AM
harleycharlie1992
thanks!
Old Feb 12, 2013 | 11:23 AM
CRocks's Avatar
CRocks
Yeah, I read if you have to install equalizers, then you have to unplug them while flashers in use. That's what concerns me, pullin the seat every time I use the flashers for an extended period. Apparently the equalizers generate a gang of heat. But, if it's REALLY plug + play, I guess it oughta fly. Thanx!
Old Feb 12, 2013 | 11:30 AM
Nute's Avatar
Nute
You would only need an equalizer if you are using LEDs for signals. Use the equalizer from Badland and you don't have to worry about heat as they have come up with a way that their equalizer stays cool. The RTB modules are plug and play.
Old Feb 12, 2013 | 12:28 PM
CRocks's Avatar
CRocks
Great, thanx much!
Old Feb 28, 2013 | 01:37 PM
CRocks's Avatar
CRocks
Got the RTB module installed + what a difference! Totally plug + play, I did have to change the rear signal lenses to red to be legal. Nice mod for about $75 including new lenses. Makes back of bike much more visible, especially with flashing enabled.
Old Feb 28, 2013 | 01:50 PM
mrwatson75's Avatar
mrwatson75
I really like the flashing feature..I run the kuryakyn one on mine and my wife's bike..
CRocks
Jun 3, 2015 05:36 PM
Flavourless
Jun 28, 2013 11:56 PM
Keithhu
Dec 20, 2012 08:39 AM
zjones
Apr 12, 2011 11:50 PM
