K&N plus Rush...Do I need...?
a stock air cleaner - only swapping the filter to the K&N is NOT the same as changing to the open element like the SE Heavy Breather or any other OPEN element
IF you swapped to an OPEN ELEMENT you need a tuner
just putting exhaust on does not mean you need a tuner either
but I would probably put the best version of the knightrider plugs into the system to help richen up the system some - cause it doesn't hurt on a stock bike, and it should be a better choice for yours now that you modified it slightly
we did the exact same set up on the wife's 2011 FatBoy - put on a rush full exhaust system and I swapped her air filter over to the K&N (although it's just a better filter in the same old football cleaner that is stock) so maybe slightly better flow, but marginal, but a better filter to keep out crap - we put on the XiEDs on her bike and the plugs do not show a lean condition
That is not correct, the stock paper filter does not flow **** compared to a K & N Filter. No matter if it's exposed or behind the "football" cover.
But if it works for you, that's all that matters.........
and on a stock back plate with stock engine, stock head pipes and simple slip ons and the K&N stocker - you do not NEED a tuner
you may choose one - sure, but NEED one - no
the XiEDs or ViEDs will handle that simple mod list
And the bike will be running leaner then when it came from the factory with aftermarket slip-ons and a high flow filter. Yes, the XiED's should richen up the mixture but their far from being a fuel management device. BUT AGAIN, if it works for you or others, that's all that matters.
http://sales.nightrider.com/2007-and...mance_b_5.html
