What should the voltmeter read with ignition on?
Old Feb 22, 2013 | 02:35 PM
UltraNutZ's Avatar
UltraNutZ
Originally Posted by Matt0987
I went to Harley-Davidson.com and set up a profile. Once done, I have access to my owner's manual. In my owner's manual there is a chart that says that if my battery voltage is at 11.8 the battery is dead. Fully charged it is 12.7 volts.
12.7 full charge
12.6 75 %
12.3 50 %
12.5 25 %
If your battery will not hold a charge of a minimum of 12.5 volts it is dead and needs replacement..
if your battery voltage drops below 11.9 volts, it sends the ECM into protect mode and it will not allow your bike to start.
Old Feb 22, 2013 | 06:09 PM
emwolb's Avatar
emwolb
batteries plus is a good place to get a premium battery too. i've had no problems with harley batteries lasting quite well, provided you use a battery tender if you're going to have your bike out of service for a couple of weeks, or for winter storage.
Old Feb 22, 2013 | 06:23 PM
ShadowMonster's Avatar
ShadowMonster
"but I noticed when I go out to the garage and just turn on the ignition switch the voltmeter only goes to 10v. Is that right?"
First off you can't tell what state the battery is in by turning on the ignition and checking any reading, bike guage or meter...... you've got lights on, fuel pump is activating, at the least, fully charge the battery and put a meter on it(with key off) and see what you have, but turning the key on and reading anything is an invalid indication of the state of the battery.
Old Feb 22, 2013 | 06:29 PM
dribble's Avatar
dribble
Old Feb 22, 2013 | 07:48 PM
RPS1981's Avatar
RPS1981
You're not getting an accurate reading at the volt gauge when the ignition is on but the bike is not running... because all your lights and the ECM are on and draining the battery as you're trying to get a reading. This will be true even on a good battery.
Leave the ignition off and put a volt meter on the battery terminals (pull the seat) to get an accurate reading.
CJHD
Electrical/Lighting/Alarm
Jul 18, 2019 11:10 AM
Theakerr
Sep 28, 2012 04:51 PM
AdamWGolen
May 4, 2012 11:29 AM
we_brown
Mar 30, 2012 01:16 PM
JohnScrip
Jul 26, 2011 09:58 AM
