Help! I need an Expert.
Old Feb 22, 2013 | 06:19 PM
HarleymanMike's Avatar
HarleymanMike
Exclamation Help! I need an Expert.
I have a 2012 Street Glide. I wired up some LED's to the acc. plug under the seat. Was gonna put a pigtail on battery for a float charger, so I took the terminals off. I noticed that I already had a pigtail on it (damn, they hid it well) so I put the terminals back on, turned the key on and....wait for it...NOTHING!! No dash lights, nothing. Checked every fuse in fuse box, all is good. The fairing is off, and there is 12v to the key on hot wire on the acc. plug. Is there a fusible link somewhere I'm not seeing?
Thanks, In advance
Old Feb 22, 2013 | 06:55 PM
Hotrodz_n_Harleyz's Avatar
Hotrodz_n_Harleyz
it's been said 4,637,492 times... but it always bears repeating. Get a shop manual for your bike. And a parts manual to. you'll have a hundred bucks in the 2 if ya buy em new from the dealer, but they're worth a thousand if you're gonna work on your bike. get one. right now. why are you still here?
Old Feb 22, 2013 | 07:04 PM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
Sure you have LED's correct. Undo the attachment and replace the 15 amp ACC fuse and try. (should be spare in fuse box) Know my old bike has an black acc lead and also a gray plug for maintenance that is similar but should have a cap on it. Not sure what the new modern maintenance plug looks like
Old Feb 22, 2013 | 07:50 PM
Iceman24's Avatar
Iceman24
Also, make sure you have the battery terminals greased & tight. If the only change from your project is the LED's...take them out of the factor, as Ripsaw suggested. Something's amiss w/your wiring so time to do things in reverse order...good luck!
Old Feb 22, 2013 | 11:47 PM
Matt0987's Avatar
Matt0987
Put it back the way it was before you started. See if all works well. Then start over. One step at a time.
Old Feb 23, 2013 | 12:08 AM
Biker John's Avatar
Biker John
Ditto! Last thing you did...
Old Feb 23, 2013 | 12:10 AM
vzts4q's Avatar
vzts4q
Thanks, In advance
Did you check the MAXI fuse that one will shut down everything.
Old Feb 23, 2013 | 12:34 AM
hd_rolling's Avatar
hd_rolling
Its been forgot to be replaced by many!
Old Feb 23, 2013 | 04:19 AM
sgdiesel's Avatar
sgdiesel
If you connected the LED through the Acc plug then the worst these can do is blow the 15A acc fuse which does not give you the symptoms you are experiencing.
As stated above, if you have checked all the standard blade fuses then go to the maxi fuse. If that is blown I am surprised you didn't see some sparks when you were working with the battery as it is a hefty fuse.
From what you describe I have a sneaking suspicion you had the ignition switch on whilst pulling the battery
Old Feb 23, 2013 | 04:44 AM
OldArmy's Avatar
OldArmy
+1. Exactly right, this is always my method any time I work myself into a trick bag (happens more often these days). Back out, get back to zero, then start again. You'll figger it out.
