P1001 System Relay Coil Open/Low EFI
Old Feb 23, 2013 | 09:27 PM
rrcap2001's Avatar
rrcap2001
Default P1001 System Relay Coil Open/Low EFI
Finished up with fuel moto 107 kit. Noticed oil leaking from acr,replaced that last night.when I went to start bike it wouldn't fire this time. One of the error codes is p1001, I did a search on it and didn't come up with many answers.any and all input helps. Also, I have no spark at the plugs.
Old Feb 24, 2013 | 06:32 AM
wtb3886's Avatar
wtb3886
Greetings rrcap2001
What year and bike is this?
Old Feb 24, 2013 | 08:17 AM
UltraNutZ's Avatar
UltraNutZ
you have other codes? might want to list them as they could very well be related to the above code...
Old Feb 24, 2013 | 08:30 AM
rrcap2001's Avatar
rrcap2001
2011 flhx
Old Feb 24, 2013 | 09:35 AM
rrcap2001's Avatar
rrcap2001
P1003
Old Feb 24, 2013 | 12:17 PM
UltraNutZ's Avatar
UltraNutZ
tell you where I'd start
1.) pull the connector off the ECM, look inside that connector for corrosion or loose pins. Put a dab of dielectric grease in that connector and mate it back together.
2.) check your battery's ground wire for corrosion and tightness.
3.) check your fusebox for corrosion on any of the fuses
Old Feb 24, 2013 | 03:03 PM
rrcap2001's Avatar
rrcap2001
Tried different plugs, changed the wires, changed the two relays in fuse box. Dealer doesn't think it is the coil, because they said they never go bad. Have power everywhere, no blown fuses, everything works just doesn't fire. No spark at the plugs. I'm still thinking ignition coil, dealer would have to order one, wouldn't be in till friday. Anything else I can check?
Old Feb 24, 2013 | 03:05 PM
rrcap2001's Avatar
rrcap2001
One more thing, bike and power vision is telling me no codes now.
UltraNutZ's Avatar
UltraNutZ
not even historic codes?
Old Feb 24, 2013 | 03:15 PM
UltraNutZ's Avatar
UltraNutZ
what is your battery voltage? if it drops below 11.9, the ECM will kill the coil.
