Decatted header
Old Feb 27, 2013 | 01:16 PM
dmorales24's Avatar
dmorales24
Default Decatted header
I have recently installed a decatted head pipe, Rinehart 3 1/2" slip ons, Screaming eagle Stage one air intake, and a power commander V. It was all installed on my 2011 Street Glide with a 96" motor. When I installed the Power Commander, it told me to disconnect the 02 sensors, so I left them on the head pipe but disconnected the wires up under the side cover. Should I remove the o2 sensors and plug the holes or just leave it as is?
Old Feb 27, 2013 | 01:37 PM
Jinks's Avatar
Jinks
Yes..........
Old Feb 27, 2013 | 01:52 PM
KCFLHRC's Avatar
KCFLHRC
Originally Posted by Jinks
Yes..........
Boy, there's a helpful post. If it were me, I would remove them and plug the holes. However, probably no real benefit to doing that other than to clean things up.
Old Feb 27, 2013 | 01:57 PM
Eshaw301's Avatar
Eshaw301
I left mine as is. No way to clean up that area because it cant be seen. If you wanna waste money plugging them go right ahead. Even with the auto tune I still left the 12mm sensors in their place on my head pipe and installed the 18mm ones from the kit.
Old Feb 27, 2013 | 03:44 PM
josame's Avatar
josame
Let us know how you like this setup once you ride it.
Old Feb 27, 2013 | 05:08 PM
SBW Cycles's Avatar
SBW Cycles
I have the same set up on my 2011 FLHX. Bike runs great. Left the o2 sensors in and unplugged just in case my pc5 stops working on the road I can plug them back in.
Old Feb 27, 2013 | 05:16 PM
troop8520's Avatar
troop8520
I'd leave them in and unplug them as well. No need to try and mess with plugging them at this point. Sounds like a sweet set up though! How she sound now?
Old Feb 28, 2013 | 08:23 AM
Jinks's Avatar
Jinks
Same answer, more words.
Old Feb 28, 2013 | 11:23 AM
billnourse's Avatar
billnourse
I have exactly the same setup on a 2012 Limited and 2012 Tri-Glide. We left the sensors in just in case the PCV quit or in the event we are in a place like Kalifornia and some air official looks at the bike. Without taking the side cover off, there is no way to tell that the sensors are not connected.
Bill
sh4325
2014-2024 Touring Models
Aug 16, 2018 09:13 PM
mjlevi
Jun 29, 2015 06:11 PM
jkeeton81
Feb 27, 2014 04:57 PM
Kentheworth
Jan 30, 2013 05:52 PM
jcp0330
Oct 24, 2010 09:15 PM
