Install help with progressive 444
Old Jun 5, 2013 | 04:41 PM
CGLTD's Avatar
CGLTD
Nope that stays. Unless there is something different with the newer bikes you can still use the quick detach feature. My quick detach wasn't a part of the stock shock. I also have to two point and not the 4. Not sure if there is a difference.
Old Jun 5, 2013 | 04:46 PM
texas steve's Avatar
texas steve
Thanks Chris, yes I have the 4 point, but a call to Progressive confirmed that it is still works. there is the second spacer (that goes up against the slip in sleeve, on the frame side) that makes the space for the QD to work.
Im putting them on tomorrow! any hints welcome
Old Jun 5, 2013 | 04:51 PM
CGLTD's Avatar
CGLTD
I think I just put one on. I called progressive with that question! I will look in the garage.
Old Jun 5, 2013 | 05:00 PM
aces&8s's Avatar
aces&8s
I just installed the 444 last month. The bushings can be tough to get in. I actually filed the leading edge to a slight bevel, oiled it, and went to the vice wraped with a rag not to scratch them. Good luck, their usually "goot and tight". OH yea , dang they ride nice...
Old Jun 5, 2013 | 05:13 PM
CGLTD's Avatar
CGLTD
I used the bushing (sleeve) that goes inside and then then metal washer. I couldn't tell if I used the plastic spacer. I don't think I did. I put the sleeve in the freezer overnight and it slid right in!
Old Jun 5, 2013 | 05:36 PM
Hukamosh's Avatar
Hukamosh
Sounds like you got it. The tan rubber thing you asked about is the bump stop and it needs to stay where it is. Happy trails
Old Apr 23, 2014 | 10:50 PM
tom071200c's Avatar
tom071200c
I know this is an old thread but it shows everything I have a question about...
When mounting the shocks, does the (#3) washer go in between the shouldered sleeve (#1) and the motorcycle- or does it replace the factory flat washer between the lock washer and the shock?
Old Apr 24, 2014 | 04:16 PM
tom071200c's Avatar
tom071200c
Called Progressives tech line. He said on the baggers, the #3 washers are not needed. The shouldered sleeve goes against the motorcycle and the stock bolt, lock washer and flat washer are reused on the outer portion. Just incase anyone runs into this again...
GunslingersNation1
Audio Systems
Jul 10, 2019 07:14 PM
Cbb129
Jul 19, 2016 11:07 AM
! rock103 !
2014-2024 Touring Models
78
Mar 1, 2016 04:11 PM
prost34
Air Suspensions
Apr 7, 2012 08:51 AM
Bryan TTM
Sep 29, 2006 12:50 AM
