Backoff Brake light flasher
Old Mar 1, 2013 | 02:02 PM
Bullitt59's Avatar
Bullitt59
Default Backoff Brake light flasher
I am looking to install this on my 2011 Ultra Classic. It goes between the switch & light on the brake wire under the seat. Anyone know where the wire is, or even better yet, have apicture or the wiring?
Old Mar 1, 2013 | 03:26 PM
BiggestDawg's Avatar
BiggestDawg
Advanced HDF Member
The wiring the brake light runs through a hole in the rear fender under the seat. If you want to put it on the TP it is on the right side (left side as you look backwards at the front of the TP. You could put it inside the TP. I see that they rate it to only run two lamps so I would think that a TP is a good choice. There is a small amount of space at the back corner of the TP under the liner that you can put that. The wiring information that I saw says that it's an inline device so just clip the wires and reassemble according to the instructions. I might consider this myself.
Old Mar 1, 2013 | 06:28 PM
Bullitt59's Avatar
Bullitt59
Thanks
Old Mar 1, 2013 | 09:19 PM
Deucedog's Avatar
Deucedog
It just gets spliced in the power wire to your brake light.
I have one on my 3rd brake light on my car as well.
zigzag930
Electrical/Lighting/Alarm
Oct 17, 2016 03:58 PM
SouthernGent
Nov 27, 2012 10:19 AM
s.ga.rider
Aug 18, 2011 07:46 PM
Panteralkn
Apr 20, 2009 07:12 PM
mjunk1
Jun 19, 2008 08:13 AM
