Dyna Caliper on Touring?
Old Mar 1, 2013 | 07:37 PM
Egldr05's Avatar
Egldr05
Default Dyna Caliper on Touring?
In need of a little help but first I should tell you what my project is. I'm doing a belt to chain conversion on my 05 touring bike and going with a 180mm tire using a Fat Bob 17X5.5 wheel and aftermarket fender.
Does anyone know if a Dyna rear caliper and bracket would fit a touring bike or would this be a bad idea? I'm trying to put a 5.5" Fat Bob wheel on my 05 and there is no way either the stock caliper or the Brembo will go. There just isn't quite enough room between the wheel and the rotor to get the caliper on. The Brembo might go with the stock 05 rotor but I'm thinking that isn't such a good idea as the stocker is a smaller diameter.
Is the profile of the aftermarket calipers smaller? I may just end up selling the wheel and going aftermarket to make this work. Any advice is appreciated.
Thanks,
Rick
Old Dec 4, 2013 | 01:20 PM
Homeward Bound's Avatar
Homeward Bound
Funnily enough, I'm just trying to find a topic that discussed, with photos, just this.
Firstly, the arm that connects the axle to the caliper is wider/heavier on the touring model. It would be up to you to decide whether this was a sensible safety option or not superfluous. It probably won't kill you; but when it does, it will.
Secondly, in a standard set up, you would need to machine a thin off the axle mount end of the caliper to make the Dyna fit. I cannot remember how much but it seem to remember it was deeper.
I cannot comment on the rest of the conversation you are attempting as I don't know the wheel. Is it a cush drive wheel ...?
Sounds like you are going to have to machine *something* whether caliper arm and/or spacers.
Old Dec 4, 2013 | 01:46 PM
bigskyroadglide's Avatar
bigskyroadglide
one of the things i had to do when i put a 17 rear wheel on my 04 was take the brake pads out of the caliper when putting the wheel back on.
this allowed me enough clearance to get the stock touring caliper back on to the stock rotor then re-install the pads.
it is not easy, but it did work and i did not have to machine anything.
this may not be the problem you are experiencing as i have no photos to reference if this may be the issue. Hope this helps
Old Dec 4, 2013 | 08:48 PM
Egldr05's Avatar
Egldr05
Thanks guys, the project was wrapped up last April.
Rick
Old Dec 4, 2013 | 11:38 PM
smithbrl's Avatar
smithbrl
So, did the Dyna caliper work for you?
SK_Vega
Jan 16, 2020 12:15 PM
katanaplanet
Apr 2, 2015 07:44 AM
800screws
EVO
Dec 24, 2014 02:16 PM
Turtles70
May 6, 2012 08:30 PM
wiseguyups
Mar 19, 2012 04:33 PM
