NEW SHIFT LINKAGE--WHAT A DIFFERENCE
Old Feb 12, 2007 | 10:17 AM
Harleypingman's Avatar
Harleypingman
Default NEW SHIFT LINKAGE--WHAT A DIFFERENCE
Replaced the OEM shift linkage on my '04 EG with the HD round polished stainless linkage with Heim joints, 33814-98A. What a terrific improvement in shifting--no slop at all; just click-click, etc. up or down shifting.
I've had the bike two years and ridden 40K. I always looked at replacing the linkage as a purely cosmetic change--boy, was I wrong. That OEM shift linkage is a piece of junk compared to the positive shifting offered by the replacement. Had I known what a huge difference this change would make in the ridability of my bike I would have made the swap within 30 days of buying the bike. Even knowing the HD stuff is over-priced, the improvement in shifting was so good I actually think the item is outstanding value.
Old Feb 12, 2007 | 10:21 AM
dugan's Avatar
dugan
Default RE: NEW SHIFT LINKAGE--WHAT A DIFFERENCE
can a person with no mechanical knowledge replace this linkage? any tips?
Old Feb 12, 2007 | 10:27 AM
Bryan TTM's Avatar
Bryan TTM
same linkage i have...love it....didnt care for the doodad'd up linkages personally
Old Feb 12, 2007 | 10:29 AM
dgator66's Avatar
dgator66
Nice tip. I never would have thought that the linkage made that much of a difference.
Old Feb 12, 2007 | 10:58 AM
BladeMan's Avatar
BladeMan
I changed mine. It looks better, but I can't tell any difference in the way it shifts.
Old Feb 12, 2007 | 02:23 PM
iclick's Avatar
iclick
ORIGINAL: Harleypingman
If the heim joint is the key, why not just buy a stock shift linkage ($25 new, IIRC) and rob the heim joint. Then you'd have two on your original linkage. I don't know why the shifting would improve, but I do know the ball-and-socket joint on the rear of the stock units will wear out and break in time. Ask me how I know this. For this reason and since I have a spare stock linkage here, I will try to adapt it to the rear of the stock unit and will report back.
Old Feb 12, 2007 | 02:50 PM
UGGA's Avatar
UGGA
I replaced my stock linkage with the same part number as you - purely for cosmetic reasons. Can't tell any difference whatsoever in shifting. It was fine stock and it's fine now. I'll bet that your stock linkage was adjusted wrong and you inadvertently fixed the problem during the replacement process. Glad it's helping you out.
Doug
Old Feb 12, 2007 | 03:00 PM
vegashd's Avatar
vegashd
ORIGINAL: UGGA
Doug
that was my thoughts as well. just more in adjustment now.
Old Feb 12, 2007 | 06:23 PM
FLGEEZ's Avatar
FLGEEZ
ORIGINAL: iclick
I have had those ball and socket mounts fall apart on my 76 Jeep Cherokkee for years. They are the same, with no good way to lube them. I did drill and attach a zerk fitting on the Jeep finally, but Heim joints are the way to go. 2 year old bke, 40,000 miles is a lot of shifting, and that been a while back for my 96. I'll take the advice and put one on.
I would hope an 06 would not have a link problem. New part for new part swap usually don't make much difference. Adjustment - lmao
Ride safe, warm and often
Old Mar 23, 2007 | 02:33 PM
casique's Avatar
casique
Can the experts give a brief description of how to replace the linkage? I just bought a Kury and was looking at mine and it is not obvious how to remove. I see/feel a nut on the back of the front part of the linkage but nothing I can recognize in the rear.
Sweetglide08
Jul 6, 2011 09:38 PM
Capt. Mike
Touring Parts
Dec 4, 2009 02:36 PM
russl179
Sep 14, 2008 05:42 PM
RANDIT
Jul 29, 2008 08:09 PM
chromedome
General Topics/Tech Tips
May 20, 2008 07:12 PM
