My edge cut collection...... Pics
Old Mar 7, 2013 | 05:59 PM
  #31
TripleSix's Avatar
TripleSix
Originally Posted by fmfpj
Love it when a plan comes together, looks really good. I never seen the headlight bezel before though..
The headlight bezel is from the "burst collection" for 2013. There is a few nice pieces.
Old Mar 7, 2013 | 06:13 PM
  #32
1sweetglide08's Avatar
1sweetglide08
Wondering if the burst collection bezel will work with a Phase 7 LED headlight?
Old Mar 7, 2013 | 06:34 PM
  #33
TripleSix's Avatar
TripleSix
Not sure. I have the daymaker. I can tell you this much, the bezel does not screw into the headlight bucket. The bezel has a lip on the back of it that catches the back of the bucket and there is a pinch bolt on the bottom of the bezel. Another thing is that you cannot access the headlight adjusting screws with the bezel on. No biggie, just need to make sure your headlight is adjusted first, which I did not since I got the daymaker and bezel new together.
Old Mar 7, 2013 | 08:58 PM
  #34
pontiac69's Avatar
pontiac69
I think it looks great. Love that front wheel..
Old Mar 7, 2013 | 10:44 PM
  #35
lh4x4's Avatar
lh4x4
Looks awesome! I think that the exhaust really goes with the set up will.
Old Mar 8, 2013 | 10:31 AM
  #36
Duke 07's Avatar
Duke 07
Nice I like it. Good job.
Old Jul 10, 2013 | 10:59 AM
  #37
Epicure468's Avatar
Epicure468
Stage I
Default Nice Job
Looks great, attached is a picture of mine. I've added a few things since this was taken . Looking forward to sending the heads out to be diamond cut.
Old Jul 10, 2013 | 11:23 AM
  #38
slammed05fatty's Avatar
slammed05fatty
looks awesome, i have same set up but wit hfew more pieces. you should look into replacing the centerpiece on the tank dash, ignition switch and the clamps for the brakeline/ clutch cable
Attached Thumbnails My edge cut collection...... Pics-2012-04-28-08.05.29.jpg   My edge cut collection...... Pics-2012-04-07-17.19.05.jpg
Old Jul 18, 2013 | 07:06 PM
  #39
SOCALHD's Avatar
SOCALHD
Nice. I have a question of you though regarding the headlight trim ring. I installed mine last night after installing the new LED light. I installed per the instructions but found there is not much of a lip to grab the bezel. After a few tries I got it on and it seems snug but for the price I am concerned it will fall off. Most other trim rings you put them over the stock one but this 1 you actually remove
Old Jul 18, 2013 | 08:12 PM
  #40
TripleSix's Avatar
TripleSix
The "lip" on the trim ring is pretty small. When I installed mine I was also a bit concerned that it could fall off. I just tried to keep pressure on the trim ring while tightening it a bit. Then I used the heel of my palm to hit it and make sure it was seated all the way. Tightened it up, and havent had any issues. Dont forget loc tite......
