Loose Fuse Connection
Old Mar 13, 2013 | 08:17 PM
berndog's Avatar
berndog
Default Loose Fuse Connection
I have an 01 rk and the headlight keeps goin out,turns out the fuse going into the slot will not stay tight,,,does anyone have suggestions ?
Old Mar 13, 2013 | 09:47 PM
05 Ultra's Avatar
05 Ultra
I just had the same problem. I twisted the contacts of the fuse a bit to put some tension on them. Other then pulling the female end out of the fuse block to pinch it together. Anyone know how to do that?
Old Mar 13, 2013 | 10:15 PM
Lowcountry Joe's Avatar
Lowcountry Joe
You can go to Radio Shack and buy a couple of fuse taps. Fit them around the legs of your fuse, and it will fit much tighter in the socket and should stay.
http://www.radioshack.com/product/in...0AAA&gclsrc=ds
Old Mar 14, 2013 | 04:51 AM
stupid_rope's Avatar
stupid_rope
this or pinch your fuse block contacts closer with a small screwdriver
Old Mar 14, 2013 | 09:33 AM
batman4706's Avatar
batman4706
Had that problem before, I put a thin coat of solder on the fuse contacts, made a spare at the same time.
jqb12
Jun 22, 2017 09:18 AM
jqb12
EVO
Jun 19, 2017 07:49 AM
Asuperglide
Electrical/Lighting/Alarm
Mar 30, 2015 12:30 PM
customchris2005
Dec 1, 2014 09:39 PM
dgriffith
Dec 28, 2008 09:17 PM
