Removable tour pack 2012 ultra limited
Old Mar 15, 2013 | 10:15 AM
DOGCOP's Avatar
DOGCOP
Default Removable tour pack 2012 ultra limited
i am trying to buy the strut covers that are listed in the instructions for removable tour pack the strut cover part numbers i get from the instructions are 47502-09 and 47504-09 i went on ebay and found some but also saw part number 47526-09 and 47522-09 that look the same. anyone have the correct numbers i need?
Old Mar 15, 2013 | 10:21 AM
Zooki1's Avatar
Zooki1
I believe the later 2 part numbers are the stk ones you took off
Old Mar 15, 2013 | 10:48 AM
DOGCOP's Avatar
DOGCOP
ok thank you ,i was looking at the pictures and they look the same that was my only problem, thanks again
Old Mar 15, 2013 | 10:52 AM
Zooki1's Avatar
Zooki1
You might want to call local hd shop and make sure but back when i did it i believe them last 2 part #'s were for the stk ones--cant hurt to double check
Old Mar 15, 2013 | 12:00 PM
jaymiller5's Avatar
jaymiller5
47502-09 (L) & 47504-09 (R) were the part numbers I used to get the street glide covers with no holes for my 2011 Electra glide classic when I went to the tour pack detach setup.
Old Mar 15, 2013 | 09:28 PM
sleighcrane's Avatar
sleighcrane
Default Strut Covers
Hey Jaymiller are those part# for the chrome covers or black ones Thanx
Old Mar 15, 2013 | 11:43 PM
BFMC Faceplant's Avatar
BFMC Faceplant
6th Gear
I just did the same thing to my limited.I used a 3/4 inch knock out tool and put two holes in my stock covers.When the mount for the tour pac go on you can't even see the holes.I suppose you could use any bit.You can see a very small gap between the cut outs for the stock mount and the new brackets but not enough for me to worry about and it's FREE.
Old Mar 16, 2013 | 10:41 AM
98Ultra's Avatar
98Ultra
I'm in the process of rounding up the parts to do this on my 2013 Classic right now. So far I have the four point docking kit. Ordered the license plate relocation bracket from Soft Brake this morning. There is a tourpak 2 up dock in one of the shops local but he wants a bit much for it used.
What is and where do you get a "3/4 inch knock out tool" ?
Old Mar 16, 2013 | 10:47 AM
Bumpandrun's Avatar
Bumpandrun
Most electricians will have a set in there truck. Nice tool
Old Mar 16, 2013 | 10:49 AM
98Ultra's Avatar
98Ultra
I just looked on ebay and those look like the stock covers. I think they have the wrong part numbers listed. The ones we want have holes for the docking kit to go through. There should not be a gap in the top where the bracket went through.
Thanks about the knock out tool also.
