Still no issues useing 89 oct!
Old Mar 18, 2013 | 07:42 PM
103 sedona orange's Avatar
103 sedona orange
I run 91 here in Cali. If they had 93 I would use that. I've gotten some bad gas when out on the road & you can tell the difference.
Old Mar 19, 2013 | 12:44 AM
Thor's Avatar
Thor
Originally Posted by Stiggy
They're low compression engines and will run regular easily, unless they get hot. Stuck in an hour long traffic jam with the thermometer hovering at 95 degrees it needed the high test that day.
And since I can't predict the next time it's gonna' get really, really hot, I'll keep the 93 in it all the time.
THIS. I'll throw 89 in during the winter (ride year-round), when ambient temp never goes above 45-50, but as soon as spring rolls around it's back to 91...too risky here with Philly traffic.
Originally Posted by NAILIT RK
I've wondered why run high octane in a low compression engine (motor's are electric!)
LOL, Thought I was the only stickler about that...Shop teacher beat it in our heads, carried it with me the rest of my years...now I lecture my kid (Senior in Tech for motorcycle/OPE)
Old Mar 19, 2013 | 09:35 AM
JCleary's Avatar
JCleary
Originally Posted by Matt0987
I was in the Sierra foothills a couple of weeks ago. As I passed a sign indicating the elevation to be 4000 feet my bike (See my signature.) was pinging, sounded like a bag of marbles, and had little power. When I got down to lower elevations everything was as normal. My bike is stock, I always run 91. As I was that day.
California gas sucks. I've talked to a couple dyno tuners about it.
Add the fact that most gas stations have one hose at the pump. And up to a gallon of fuel resides between the valve in the pump and the nozzle. So if you always fill up when you have a 1/2 tank (like a good friend of mine does), and the person before you used 87, it's likely you're get mostly 87-89 octane in your tank.
I always go to Chevron, where you can tell what the person before you pumped. I find a pump that has an arrow over the 91 price and use that one. I never seemed to have a pinging issue doing that.
Old Mar 19, 2013 | 09:41 AM
Matt0987's Avatar
Matt0987
Had not thought of this. My local Chevron - where I typically fill up - has the one hose machines. I will have to check out the Shell across the street to see if they have the 3 hose machines.
Old Mar 19, 2013 | 09:43 AM
mgmmgm's Avatar
mgmmgm
I was in Northern Cali last August down by Ft. Bragg. Fuel was not real great, Seafoam helped out the situation. Would like to have access to 93 octane fuel, as it is I can get non-corn 91/92 octane, will stay with that.
On a side note, my 04 mazda 3 was dropping mpg added seafoam, corrected the issue.
Old Mar 19, 2013 | 09:50 AM
Frankenbagger's Avatar
Frankenbagger
Originally Posted by plutnicki
The money never made sense to me either. I put 7k miles a year on the bike and get like 40mpg, which amounts to 175 gallons of gas. Where I fuel up, 89 is about $0.10 cheaper, so that amounts to saving, $17.50 a year...
Not even worth the thought, IMHO.
Exactly. Even at 25k miles a year I only stand to save $62.50 a year by running lower octane. Seeing as I have always run 93 and never had problems with pinging, I'll pass. Maybe 87/89 would also work just fine and I'm squandering almost $70 a year paying for premium, who cares??? Not this guy...
Old Mar 19, 2013 | 01:07 PM
djaudette's Avatar
djaudette
Funny, I've always stayed away from 89 octane in all my vehicles, maybe it's just me but see most people tend to use either 87 or 93, so I always suspect the 89 sits around the longest in the tanks and collects water... Maybe that's crap, dunno...
Nice job in breaking that down for us. Have always used the 91 without thinking about it. 6 gal tank if empty would cost .60 cents more per tank full. Your right, not worth the chance
Old Mar 19, 2013 | 01:55 PM
Eshaw301's Avatar
Eshaw301
Lol...this is probably one of the best explanations I have ever heard on this forum. When you break it down like that, it makes it all seem so silly to even mention the difference between the 2 octanes....
Old Mar 19, 2013 | 04:06 PM
2004Sierra's Avatar
2004Sierra
The 91-93 octane requirement is all about detonation and pre-ignition. These motors run hot, even with a tuner and even at 12.8 to 1 they run way hotter than our cages.
When prolonged detonation or pre-ignition occurs cylinder head temps go through the roof, plus it can melt a hole in a piston. I have seen it happen.
Why on earth would you put your engine in jeopordy over a few cents. Fuel quality today is questionable anyway, especially since we are burning a corn mixture.
Use whatever you want, but I have far too many $$$$ invested in my bike to chance squeezing a few pennies at fuel-up. As for me I will continue to run 93.
Old Mar 19, 2013 | 04:17 PM
lh4x4's Avatar
lh4x4
bob2002:
Cobra Fi2000r. Not the Pro model which only operates during acceleration. I have run these bikes all over the North American Continent and put 25K or more a year combined on them. My bikes run cool strong and have no issues at all. No pinging.
Pinging has more to do with operation and maintenance than the octane of gas. Lugging is the primary cause not doing carbon cleaning is the other .
Some do not know that the nanny government requires all manufacturers to produce engines that run on 87 octane. That is why HD can only recommend 91 or better and not require it. I did the same with my Corvettes and Viper without any issue also. Had the same number of posters there claiming the engines would destroy themselves. Drove one seven years, two of them four years and one for three years. All ran great. They are now trying to do with small aircraft what they did with cars. They are trying to get aircraft engines limited to 87 octane also.
Some folks like to argue against success. The lower compression HD motors will run just fine. It is how you operate and maintain them. If the use of 87 octane would put the engine at risk then it would have happened on one of the 10 bikes and 5 sports cars. So I call total BS on those who claim that they would destroy themselves. Total BS.
Of course if the bike is modified with higher compression, race cams and what not the higher octane is needed. Just not needed for stock set ups.
