Power Vision License Question
Old Mar 19, 2013 | 01:50 PM
hattitude's Avatar
hattitude
Originally Posted by skratch
i know for sure. i'm currently doing it. i have my bike and a license for the wife's bike in it. and yes, it is a firmware update, though the actual number of the update that allows it i'm not sure of.
Thanks for the confirmation.....!
I'll do the update sometime this week....
Old Mar 19, 2013 | 03:43 PM
skratch's Avatar
skratch
before you even talk with roy, get a hold of jamie (if you got your pv from fm) and get you a good map for your second bike. then after you get your license, you'll be ready to start. if you didn't get your unit from fm, then ask for a map at the same time that you are doing your license.
the process really surprised me. you have to contact dynojet with your cc number (and all the pv info, he'll tell you what and where to get it from) so they can run it, then afterwards, they will email you the license that you punch into the pv. i was expecting it to take a couple of hours or so, but i had the code within 5 minutes.
Old Mar 19, 2013 | 05:48 PM
VTL nut's Avatar
VTL nut
How many digits is the code?
4 or 10?
Thanks
Old Mar 19, 2013 | 07:14 PM
kipd's Avatar
kipd
My Dual License code was 10 digits
Old Mar 19, 2013 | 09:27 PM
hattitude's Avatar
hattitude
I already have two codes and maps for both my bikes. Currently I need to add and remove the license code, to go back & forth between each bike.
Once I do the update on my PV, where I can load both codes into my PV at the same time, will I need something else from DynaJet to get it to work?
Just FYI, I got my PV and maps from Jaime, but he didn't have a map for my '03 Heritage w/big bore kit. I got that map from DynaJet and the bike runs excellent.
Old Mar 20, 2013 | 05:02 AM
skratch's Avatar
skratch
since you have both codes already, you shouldn't. i had already done the firmware update when i got the dual license code.
Old Mar 20, 2013 | 10:11 AM
hattitude's Avatar
hattitude
Thanks.....
omalley72
Jan 19, 2019 11:21 PM
RiverSouth
Aug 20, 2017 04:37 PM
04ctd
Sep 5, 2014 06:11 AM
jake40ma
2014-2024 Touring Models
May 17, 2014 05:14 PM
chainsaw123
Apr 3, 2014 04:41 PM
