Raked Bagger
Figure out what you need for a wheel and fender, if you're going to be changing your brake configuration, etc. I have about 2500 all in, wheel, rotor, fender, six piston caliper, brake line, trees, and materials to rake the frame. I went with a 23 inch front wheel, I know there are guys running 23 with just trees, no frame rake, but I feel that you need to rake the frame to properly run a 23. I raked my frame 7 degrees, and run +3 degree trees for a total rake of 40 degrees. The wheel is kicked out just a bit, the frame is level, and you don't need to take travel out of the suspension. Trail is slightly increased from stock, which is a good thing with these bigger wheels.
I like the look of the 26 inch front ends, but for my purposes, a 23 was more practical.
As it sits tonight, but I'm fixing to tear it back down for a conversion to a Road Glide front end.
