Hard start Issue / Very Odd
Old Mar 18, 2013 | 06:39 PM
Renold's Avatar
Renold
Default Hard start Issue / Very Odd
O7 SG with Thunder-Max tuner. It has been starting good up until recently. I have been doing some 2-3 hour weekend trips. After about an hour or so of straight riding at about 80-85 MPH and then a fifteen minute break the bike does not want to start. ( I was going to call Zippers today but did not have time.) After a few attempts it will finally start. It just turns over when it is not starting. The last time it did this I just kept it turning and it finally fired up. Only seems to be after a long stretch at 80+ MPH when the engine is at full operating temp.
I was kinda thinking maybe something in the map at a certain temp on start up. I just am not sure and I am I open for suggestions.
I just came back from Savannah Georgia. I thought I was going to have to stay at one point LOL.
Old Mar 18, 2013 | 09:05 PM
Renold's Avatar
Renold
Old Mar 18, 2013 | 09:12 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
a few 07"s have had idol issues after long runs,but with the thunder max ??,for most it was a tps.tps adjustment ,iac,and even a speed sensor,or crank position sensor.start with the iac,its otop the throttle body remove the air filter and u will see a small hole, with ignition on u can actuate it by flipping the run switch,spray it with some carb cleaner if it helps but returns replace it.as for the rest i can't help with the thundermax.
Old Mar 18, 2013 | 09:14 PM
bigskyroadglide's Avatar
bigskyroadglide
Have a friend who had the same issue with his 09 ultra. We were at bike week in Daytona and he had zippers perform a firmware update on his thundermax. It seemed to solve the problem. Not certain if this is the same issue, but apparently some software updates have come out for the thundermax.
BurgundyUltra06
Nov 1, 2024 01:37 PM
smackay
Jun 26, 2016 08:20 AM
TimBob2010
32
Dec 30, 2013 10:28 AM
Bingo
Oct 16, 2012 12:35 PM
2007fxdc
Mar 28, 2008 07:59 PM
