gap between controls and wild1 bars
Old Mar 18, 2013 | 06:51 PM
keno's Avatar
keno
Default gap between controls and wild1 bars
I installed wild1 578's and have a gap between controls on clutch side. I read a post on how to slip them up against the 1-1/4" portion but can't find it. Anyone remember where it is?
Thanks much..
Old Mar 18, 2013 | 06:58 PM
C908's Avatar
C908
I have Wild One 577's and experienced the same thing. When I asked if others had experienced this the answer was yes. Some had said they just cut a little off the bar to correct the problem. I just left mine like it was since it was such a small amount showing.
Old Mar 18, 2013 | 07:19 PM
user 8373900's Avatar
user 8373900
The instructions say to cut off a 1/2" on the left side or they won't slide up all the way.
Mark
Old Mar 18, 2013 | 09:03 PM
Gunnysgt's Avatar
Gunnysgt
Hmmmmm I have 577s and my controls slide right up to the fat section. Using HD streamliner grips.
Old Mar 18, 2013 | 09:14 PM
keno's Avatar
keno
Onedownand5up, where did you find these instructions:"The instructions say to cut off a 1/2" on the left side or they won't slide up all the way". My wild1's did not come with any instructions on it. I have the HD Get A Grip grips. Throttle side fits fine but Clutch side has a good 1/4" gap.. Fugly!
Old Mar 18, 2013 | 09:30 PM
scumBAGGER's Avatar
scumBAGGER
I just did the wild1 bagger bars and had same issue....I wrote wild1 and was told the grip was the issue i then started a thread here to see what everyone else has seen ( thought this was my thread when I read the header) and was told to cut it also but the problem was i had gap on both sides and fly by wire would take someoine good to cut that.........so i went to HD and comared grips with the set I bought and what was on the shelf, dealer said they are all the same but something just did not look right when i held them up to the kyreyokin grips they had on shelf!!!!!the grip i bought from hd was a new grip they have in the catalog dealer again said they are all the same and blamed wild 1 bars........I prurches the kyreo grips and they worked great closed both sides up and look great...fuHD and your cheap made stuff (not saying kyro is any better)......hope this helps....sorry about spelling at work and no friken spell check!!
Old Mar 18, 2013 | 09:31 PM
user 8373900
I have a limited with heated grips, the web site says.
Our bars are designed to work on the vast majority of Stock HD equipment.
The HD heated grips are shallower than the OEM standard rubber grips.
You may have to trim 1/2" off left bar end so everything butts up to 1-1/4" section.
Mark
Old Mar 18, 2013 | 09:32 PM
scumBAGGER's Avatar
scumBAGGER
yeap thats them get a grip was not happy as I like the looks and feel of that grip but did not work....took a 20dollar hit on them to sell to friend
Old Mar 18, 2013 | 09:33 PM
scumBAGGER's Avatar
scumBAGGER
Mark
get a grip not heated
Old Mar 18, 2013 | 09:37 PM
Griff012FLHX's Avatar
Griff012FLHX
I just had my wo577 installed....
Clutch side has about 1/8 gap.
Other side flush.
