Engine Shake Riddle
Old Mar 25, 2013 | 06:20 PM
FL-kruzen's Avatar
FL-kruzen
Default Engine Shake Riddle
I always wanted to know why the rubber mounted engine in touring models are not replaced with the rigid mounted balanced engines that are in the soft tails? Why the two different types at all! It would seen to me that the touting models would have the balanced, non-shaking engine in the first place. Any thoughts on this?
Mark
Old Mar 25, 2013 | 06:23 PM
Jackie Paper's Avatar
Jackie Paper
Softails are a different line sold to wusses. Real men buy cruisers and it would hurt the company's bottom line if they had a TCb motor. The Softail has a rear swing arm independent of the motor were Cruisers and Dynas rear swing arm is attached to the motor.
Old Mar 25, 2013 | 06:26 PM
FL-kruzen's Avatar
FL-kruzen
I'm not going there..
Old Mar 25, 2013 | 06:38 PM
RoadKing2438's Avatar
RoadKing2438
From what I understand, although the touring models shake while at idle, they are smoother while rolling down the road. Where as the softails don't shake while you are at idle, you actually feel more vibration while rolling down the road. I personally haven't spent enough time on a softail to be able to tell the difference.
Old Mar 25, 2013 | 06:57 PM
scrawfordFLSTC's Avatar
scrawfordFLSTC
I have owned both and that is absolutely true.
Old Mar 25, 2013 | 06:58 PM
Loc_Tite's Avatar
Loc_Tite
Plus I like the shake anyway.
Old Mar 25, 2013 | 07:04 PM
heritageblue2013's Avatar
heritageblue2013
My 13 Softail is smooth at the light, while cruising, and smooth with the ladies.
Old Mar 25, 2013 | 07:12 PM
BBStacker's Avatar
BBStacker
The shake is nice "if" there is bewbidge over the rear wheel.
Old Mar 25, 2013 | 07:13 PM
dribble's Avatar
dribble
I have both and the touring bike is smoother cruising. It also has more power because counter balancers rob power.
I have heard that the Softails are solid mounted because that's the only way to fit the engine in the frame, otherwise they would have not counter balanced and rubber mounted them instead. The EVO softails were a source of vibration complaints and I believe that is why the TCB's were manufactured.
Old Mar 25, 2013 | 10:37 PM
Fishrrman's Avatar
Fishrrman
The touring frame goes back to 1979, when the only big twin HD engine was the Shovelhead. The rubber-mounted frame was quite an innovation (at least for HD) at the time. It's roughly the same design that they're using today, with revisions, of course.
That frame lasted from the Shovelhead through the EVO years, and into the TC years (88, 96, now 103). It pretty much "worked" so they didn't change it so much as refine it.
When they introduced the TC88b (counterbalanced) motor in 2000, I thought they might incorporate that design into the rubber-mounted frame as well (to produce a motor with as little vibration as possible throughout the rpm range), but didn't work out that way. Guess the factory and designers figured they had a design that had sold bikes for decades, so why change it?
