heads
Old Mar 26, 2013 | 05:00 PM
bigboy92's Avatar
bigboy92
Default heads
Will a 2003 flhtcui head fit on a 2005 flhrsi?
Old Mar 26, 2013 | 05:04 PM
Frankenbagger's Avatar
Frankenbagger
Shouldnt be a problem. Same 88ci fuel injected twin cam touring motor. Obviously no performance benefit, but itll work for a repair or any other reason
Old Mar 26, 2013 | 05:06 PM
bigboy92's Avatar
bigboy92
Repair is the reason broke headerstud with easyout broke in it
Old Mar 26, 2013 | 05:13 PM
Frankenbagger
damn, thats a tough one. I was in the same boat a couple months ago. I ended up borrowing a JIMS fixture to drill the entire stud out of the head. Then you just clean the threads in the head out with a tap. I was to afraid to break an easy out off in there, ive broken them in less critical places before and your not drilling those things out.... Just something to consider if you're ever there again (hopefully you wont need to though).
Old Mar 26, 2013 | 10:43 PM
$tonecold's Avatar
$tonecold
I don't know if you just have the replacement head or if you are buying it, but since you are removing the head anyway, if you take the head with a broken stud to a machinist they will be able to remove it, even with the ez-out broken off in it. I would go to the dealer to pick up a couple new studs so they can install them while they are at it. Probably won't cost any extra. I have done this a few times, last summer the latest, and I have never known a machinist to not be able to remove the broken stud, ez-out or not.
Old Mar 26, 2013 | 10:47 PM
C.H.L.'s Avatar
C.H.L.
If you want to fix it right, the only thing to do would be drop a 124" in there
Old Mar 26, 2013 | 11:19 PM
bigboy92's Avatar
bigboy92
Yea ill be taking it to a machinist first
leafman60
Exhaust System Topics
20
Nov 20, 2018 03:38 PM
terryfromtn
Jan 10, 2012 06:41 AM
leafman60
Dec 4, 2011 11:36 AM
speedracer
Jan 25, 2011 07:02 AM
hdrk07_61
Sep 17, 2008 10:04 PM
