To dyno or not
Old Mar 28, 2013 | 04:29 PM
  #31
sporacer's Avatar
sporacer
Originally Posted by wurk_truk
I call real live BS on a dyno will kill your bike. That IS ridiculous!
If I were to tune your bike, I won't but just say i would... I only 'tune' all of the cells up to say.... 4500 rpm. Then, I tune WOT until I get max HP and TQ from fiddling with the timing. All of the cells above 4500, I will run thru them one time to make sure everything is safe. The 80+ KPA or the 90-100% throttle is whats happening, and that too can be fiddled with one or two pulls ABOVE 4500 for verification purposes. A decent tuner will NOT make the bike rev to 7k and hold it there for and hour.
Reason for this is simple... How many folks RIDE at 5k rpm's? A Lot will get to 5k and even surpass it, but isn't that at, or near WOT?
Most here have NEVER had a bike dyno tuned, nor have they seen it done, so they just believe about anything said... most of which is FALSE.
Most tuners will agree with me on this... once a customers bike is up on the wheel, THAT is the most important bike in the world. I have my bike and a few others to 'play' with and a customer's bike is ALL about the business at hand. I, and others, will NOT tune a bike to its ragged edge either. There WILL be a horse or two left. MY goal, and most others is to generally maximize power across the board, but more importantly make the bike the best riding bike it can be! EXCELLENT manners with no surging, popping, bogging down, etc.
This is the way a tuner wont beat the crap out of your bike.
Old Mar 28, 2013 | 04:48 PM
  #32
1st 96 ultra's Avatar
1st 96 ultra
best thing I can tell you is go listen to one on a dyno then see if you want to put your bike through that , I have heard them and it is not for me
Old Mar 28, 2013 | 06:15 PM
  #33
Billyram's Avatar
Billyram
My bike stays wide open longer smart tuning than one would ever see on the dyno. The dyno tech can keep a check on engine temps and shut down before things get too hot. They're not going to anyway with the short runs on the dyno. You make a run and then shut down and make changes.
Billy
Old Mar 28, 2013 | 11:33 PM
  #34
103megawatt's Avatar
103megawatt
Originally Posted by faither
My bike is a 2010 flhtk with power duels,monster ovals,S/E hi flo A/C and a S/E pro tuner.Runs great but have been told I'd get optimal performance and mileage if dynoed.We have a great tuner in our area ,is it really worth it.
Does your bike have any decel popping? Are you getting good mileage? If no & yes answers then don't worry about the performance gains a good Dyno tune will get you. A couple hp difference is not going to be noticeable, especially if you find the Dyno cost to be an issue to your pocketbook.
Old Mar 29, 2013 | 07:41 AM
  #35
lionsm13's Avatar
lionsm13
Originally Posted by fxdwg_rugby
Save your money till you add a cam or head work...
Yep!!
Old Mar 29, 2013 | 09:28 AM
  #36
drs0413's Avatar
drs0413
I have a couple of questions, have a 2001 Electra Glide with the 88 ci motor. Have put the high flow air filter and Rhinehardt True Duels on it and installed a Power Commander from FuelMoto. Bike backfires when decelerating and gets crappy, 28-30 mpg. Mostly ride on freeway at 75-80 mph and am happy with the power. Went to Colorado last summer and got 41 mpg at higher elevations, then back to 30 mpg at sea level. I don't think the Power Commander helped me at all and called a local tuner for a dyno tune and he told me a dyno tune would not help my bike. Does anyone know a dependable shop in San Diego area, dealers are hit and miss to me. Any advice is appreciated.
Old Mar 29, 2013 | 09:30 AM
  #37
senna's Avatar
senna
I'd be willing to bet, that those who are against dyno tuning, have never bumped up against the rev limiter either.
Old Mar 29, 2013 | 10:29 AM
  #38
DeneFXDWG's Avatar
DeneFXDWG
Originally Posted by $tonecold
I would say a good tuner will probably do about 15-20 pulls during a tuning session. I wouldn't think there would be damage unless there was something wrong in the first place.
I would think they would do more pulls than that. Most good tuners will tell you they will go through a lot of fuel, (1+ tank) and need the bike for a good part of a working day. So I think they crank it more that only 15-20 times, I might be wrong .
Old Mar 29, 2013 | 11:03 AM
  #39
$tonecold's Avatar
$tonecold
Over a tank of gas?!! Most tuning sessions shouldn't last more than 3 hours and that is if they have to build the map, that shouldn't be necessary in most instances. I am talking about WOT pulls here. There could be more time spent with load control eddy current to simulate driving conditions. Unless they are doing a break-in on the motor I just don't see it taking most of the day and 1+ tanks of fuel.
Old Mar 29, 2013 | 11:15 AM
  #40
shorelasHD's Avatar
shorelasHD
Originally Posted by 2012SuperGlider
I read an article online not long ago that went into a lot of details for upgrading and maintaining a Harley. In this article it said that you should not get a dyno tune unless absolutely necessary because when done it simulates extreme driving and drag racing a bunch of times. When this is done it puts stresses on your bike far beyond normal riding and can cause excessive wear on the engine as well as possible stress fractures in the frame and transmission damage. All these systems may well not fail during the test but may take years off their usable life.
Any thoughts on the subject?
Am I missing something? That's like saying don't brush your teeth because you might get more dates and catch an STD! The poster has his point, it's his bike and his money. I just did a Stage I, w/o download, waiting for my XiEDs, but I'll save the dyno for after the SERT and cams- that's just me.
