To dyno or not
Old Mar 29, 2013 | 01:56 PM
  #41
103megawatt's Avatar
103megawatt
If a bike grenades while on the dyno, that engine had a problem before it was put on the dyno. And that is exactly where you want it to fail on a stationary platform inside a building. You do not want that problem to reveal itself when your on the highway trying to pass a semi accelerating to get around the big truck while in traffic.
People get real surprised at a dyno run because it is one of the few chances you get to stand close to a bike running hard and you feel the ground shake with all the noise and energy. Just because YOU are not accustom to seeing and feeling a bike motor at WOT on a dyno does not mean that dyno tuning will hurt an engine.
Old Mar 29, 2013 | 07:22 PM
  #42
03psd's Avatar
03psd
Preach it brother. My bike is at Doc's Performance right now. I dropped it off this morning for him to install 57H cams, HD Heavy Breather and YES, absolutely, tune that bitch on the dyno. Doc is one of the most respected tuners / builders I have found anywhere. He and I talked this morning for 45 minutes about tuning and the importance of putting a bike on the dyno and dialing it in. Anything less is a WAG. He told me that every bike is different no matter if they are all the same year and mods or stock. If you go with a stock MAP or a canned MAP at best you will get is "close". When he developes a custom tune it takes into account everything specific to your bike. Doc will not sell MAPS, even though he has been asked to many times and could make a fast buck doing so. Why not? Because at best they would be "close" in whatever bike they go in. A worst, they may be "horrible" and then customers would bitch that his MAPS suck. What do you expect? Universal fit = fits everything sort of and nothing exactly. After spending $18k to get my bike to where it is now, I want it to run its absolute best and the only way this can be achieved is thru a dyno tune. I gladly signed Docs waiver for him to dyno it. If it blows I know it had issues and would have grenaded sooner or later.
Old Mar 29, 2013 | 10:55 PM
  #43
DeneFXDWG's Avatar
DeneFXDWG
Originally Posted by $tonecold
Over a tank of gas?!! Most tuning sessions shouldn't last more than 3 hours and that is if they have to build the map, that shouldn't be necessary in most instances. I am talking about WOT pulls here. There could be more time spent with load control eddy current to simulate driving conditions. Unless they are doing a break-in on the motor I just don't see it taking most of the day and 1+ tanks of fuel.
I have to agree $tone, my tuner is the best around and more than three hours seems excessive for sure especially when a popular tuner would have a zillion 204 cam base maps in his computer like I had in my totally generic motor. The bike ran great for $500 and I don't care if it took him 3 hours or a day like he said it would. I gained 5 hp and 5 tq for that $500 but for peace of mind knowing it isn't lean was worth it.
Old Mar 30, 2013 | 12:04 AM
  #44
Eshaw301's Avatar
Eshaw301
A sucker is born each and every day!!
Old Mar 30, 2013 | 12:30 AM
  #45
DeneFXDWG's Avatar
DeneFXDWG
So I'm a sucker for choosing to get my bike dyno'd?
Old Mar 30, 2013 | 03:24 AM
  #46
GETRICKD's Avatar
GETRICKD
2nd Gear
Smile To dyno not
Its not about the numbers = $$$ or the pride. Its about the Ride Clyde!!!!!
Old Mar 30, 2013 | 06:19 AM
  #47
user_1534GD's Avatar
user_1534GD
My 2009 Ultra (stage-1) has been dyno'd twice and I HIGHLY recommend it... A dyno is expensive but worth it IMO... Just prior to the dyno make sure all the oil is changed/fresh... The process is about as near-perfect a diagnostic/tuning procedure as you are going to get and when done properly the stresses are minimum... Dyno(s)/Doctors are not perfect (but they are excellent)... Mistakes can be made, cells can be overlooked especially in the 'weird' areas... I would caution to look most carefully at those cells/KPa scenarios that are true 'outliers' particularly those that will only get exercised at high elevations when it is extremely hot and the bike is heavily loaded going up long/steep inclines...
As far as the waiver-thing goes... The dyno tech may not know the existing condition of the engine (it could be a 'set-up') AND if you sign a waiver under any duress or if the operator is negligent renders it null/void... Courts/judges often frown on waivers... Sure, I'll sign your waiver, but that doesn't necessarily mean that I have no rights...
Old Mar 30, 2013 | 06:46 AM
  #48
bundy43's Avatar
bundy43
so why does a tuner make you sign a waiver before he will tune your bike ?
Old Mar 30, 2013 | 06:54 AM
  #49
Billyram's Avatar
Billyram
One of the biggest advantages the dyno has is you can generate data much quicker than smart tuning data on the street. Smart tune live makes it easier to home in to areas you want to tune. It seems to me after updating to the latest software cells are easier to load. After a 40 min data run on my new bike smart tune had about enough cells filled to rewrite the whole map. Still after I'm done tuning it'll go on the rollers and something will be found that I missed.
Billy
Old Mar 30, 2013 | 07:07 AM
  #50
Harleypingman's Avatar
Harleypingman
Because the tuner has no idea about the mechanical soundness of the engine and drivetrain.
Carl
