Using the Starter Motor for Reverse
Old Mar 27, 2013 | 09:26 AM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
Trying to wrestle mine backwards through the soft ground of the back yard is what got me thinking more seriously about a reverse. I can definately see myself getting into a jam with this bike where I'm effectively stuck somewhere because I can't move it backwards to get out.
I've looked at the mechanical reverses. Don't want a reverse enough to spend the money on them, yet. So I was ruminating about ways to do it cheaply, which is how I got to the thought of using the existing the starter motor. Fabricating an adaption of the Goldwing design and such wouldn't save me anything over the existing mechanical reverses. Nor probably would rigging up a friction roller reverse.
I like swap meets. So, if I find a cheap starter motor assembly, I may well pick it up anyhow to play with. Probably wouldn't ever amount to anything, but if I could rig it up to play reverse for under a $100, well, that could be nice. Particularly for those times I find myself in a jam.
Old Mar 27, 2013 | 09:53 AM
TUCCI's Avatar
TUCCI
I concluded that if I have too much difficulty moving a RK, in other words my body strength has reached the point where its no longer possible, that I 1)stop riding because its time to quit. 2)go to a trike or 3)go to a smaller more maneuverable bike. Now that's my expectations as I get older and in no way impose it on everyone else knowing fully that older gents are different in their capabilities physically and financially.
Old Mar 27, 2013 | 10:54 AM
shooter5074's Avatar
shooter5074
From: Western Illinois, land of bad roads, and corrupt politicians
Just tell the bitch to get off and push
Old Mar 27, 2013 | 01:15 PM
foxtrapper's Avatar
foxtrapper
I ride solo, so there's no one else there to push.
I'm not weak. When a 700+ lb bike is sunk down an inch into soft dirt and it has to go backwards, it ain't moving easily, regardless of my strength. Same when I've got to try to shove it backwards up a hill or over a berm.
Am I planning on buying a mechanical reverse? No, not yet. But living with this bike is rapidly showing me that having a reverse sure would make riding it a lot easier and more care-free.
Old Mar 27, 2013 | 01:45 PM
make it faster's Avatar
make it faster
If this is related to moving the bike across the yard I suggest some paver stones. I ran a nice strip of pavers from my driveway to my shed to get bikes in there for the winter. Worked like a charm.
Old Mar 27, 2013 | 02:01 PM
vanman59's Avatar
vanman59
Talking do what the rest of us do
Tell the wife to push you back before she gets on. Gives her a work out and makes you feel like more of a man than needing a reverse kit. Definitely not as cheap as a mechanical reverse kit though...
Old Mar 27, 2013 | 02:39 PM
RPS1981's Avatar
RPS1981
Originally Posted by foxtrapper
I'm sure I'm not the first person to think along these lines.
I wouldn't be too sure about that.
Old Mar 27, 2013 | 02:40 PM
Joe12RK's Avatar
Joe12RK
you might be able to rig one of those rubber wheels that push on the back tire for not to much money...
Old Mar 27, 2013 | 02:49 PM
PhoneGuy-MI's Avatar
PhoneGuy-MI
x2
Old Mar 27, 2013 | 03:11 PM
Uncle Paul's Avatar
Uncle Paul
I saw some drawings of a system Harley is working on. The reverse runs off the water pump pulley. (Hope I did not spill the beans : >)
