Transmission/crankcase common?
Old Mar 29, 2013 | 12:36 PM
toketee's Avatar
toketee
Default Transmission/crankcase common?
I can't see how the motor oil and the transmission oil are kept separated. I never really thought about it until yesterday when I was working on a transmission oil leak. I had the shop manual out and got to looking at the pan and couldn't figure out how the two systems are separated. The baffle shown is the only thing that looks like it may play a role. Probably a dumb question, but I can't see how it works.
Old Mar 29, 2013 | 12:41 PM
Frankenbagger's Avatar
Frankenbagger
The engine crankcase and transmission case are completely separate pieces, just bolted together. No oil passes between them. The oil pan for the engine oil is attached to the bottom of the transmission, but does not share fluid with the transmission.
Old Mar 29, 2013 | 12:58 PM
Scuba10jdl's Avatar
Scuba10jdl
The drain screw for the transmission, while located on the pan, actually just plugs a passageway that goes through the wall of the oil pan and up into the transmission. It never mixes despite the perception that they're from the same place.
Old Mar 29, 2013 | 01:23 PM
toketee's Avatar
toketee
Thank you, kindly. I thought it had to be something like that, just couldn't see the forrest for the trees.
rossn2
Dec 26, 2014 06:46 AM
nh-trekker
Oil Archive (no new posts)
Aug 12, 2012 06:22 PM
jberg
Oct 11, 2011 01:05 PM
dynadiver
Nov 17, 2007 11:13 PM
SCS
Jan 5, 2007 01:02 AM
