How do you know
Old Apr 3, 2013 | 08:51 AM
hyperfocal's Avatar
hyperfocal
Default How do you know
2009 Electra Glide Classic
I have a stock engine with no changes to air flow. Just put on a set of 4.5 pro muffler slip on's from Fuel Moto. How can you tell if you need to tune the engine or just leave it alone?
Tech's say if you don't change air intake everything should be good.
Also, it depends on the engine itself. Some make the adjustments it needs and some don't.
I just don't want to damage the engine. Again, is there a tell tell sign that might question the engine's ability to compensate for the change in less back pressure?
Thanks for your help!
Paul
Old Apr 3, 2013 | 08:57 AM
KCFLHRC's Avatar
KCFLHRC
The best way is to look at the plugs. If they are white and chalky the bike is running lean. Your ECM should compensate just fine for the slip on's. If you add an air kit then you will need to get a tuner.
Old Apr 3, 2013 | 10:16 AM
Eshaw301's Avatar
Eshaw301
That method is pretty much non credible anymore due to the advancement of fuel injection and better fuels, machining, etc. What the tech said was correct. Exhaust change wont affect af ratio. It will just change backpressure which has an effect on the powerband. Tuner is not needed for slip ons. But tuner is definitely worth its price in gold. That was the first thing I did to my bike.
Old Apr 3, 2013 | 10:59 AM
hyperfocal's Avatar
hyperfocal
That makes a lot of sense. If you want the power back you need a tune.
I am sure I will be doing a tune real soon.
Thanks for input!!
Paul
commander112
2014-2024 Touring Models
Apr 8, 2018 06:02 PM
P51Driver
Apr 20, 2013 10:02 AM
jodynielsen
Feb 20, 2011 07:53 PM
jnv753
Aug 5, 2010 05:21 PM
FAUVDOG
May 8, 2010 08:53 AM
