Neutral light doesn't come on...
Old Apr 5, 2013 | 11:37 AM
EFritch1's Avatar
EFritch1
5th Gear
Default Neutral light doesn't come on...
Anyone else have this problem? Bike is an 06 Ultra Classic. It does work more than not, but just bothers me it doesn't always illuminate yah know!!?
Appreciate the feedback!
Old Apr 5, 2013 | 01:07 PM
mrfikser's Avatar
mrfikser
check the plug wires on the nuetral switch ..mine were loose once and the light didn't come on...also the cruise didn't work if i remember right...
Old Apr 5, 2013 | 01:34 PM
semiret's Avatar
semiret
Yeah - what he said.
If the light sometimes works and sometimes doesn't, that sounds like a loose connection.
Old Apr 5, 2013 | 01:46 PM
EFritch1's Avatar
EFritch1
5th Gear
Thanks guys, for the fast response! With that said, I'm not a gear head...at all...hate to say, so where are the wires at? The cruise works just fine too. I was thinking maybe a short, but fig I'd ask first. Funny how it didn't do it on my few test rides before I brought the beast home though ....
Old Apr 5, 2013 | 02:18 PM
DanDman's Avatar
DanDman
On top of the chrome transmission cover, two wires. Get a HD service manual or a Clymer. Pays for itself on the first use.
Old Apr 5, 2013 | 06:27 PM
semiret's Avatar
semiret
This may not be of any help, but I have a 2011 Road King.
The neutral switch is on top of the trans, as was mentioned before.
It's right by the starter
Anyway, there are two wires. On mine, they are tan and black.
I believe this is a grounding switch, which means you should be able to connect the tan wire to ground, turn on the key switch, and the neutral light should come on.
If it works all the time, then your problem would be the neutral switch.
Hopefully someone a lot smarter than me will pop in and confirm or deny what I .
Good luck
Old Apr 6, 2013 | 08:20 AM
semiret's Avatar
semiret
Went out and checked mine this morning. Noticed I have some very slight corrosion on the insides of the wire connections. It's not enough to stop the light from working, but maybe you have more corrosion on yours
Old Apr 6, 2013 | 08:38 AM
rhlhamlet's Avatar
rhlhamlet
Had this happen to me after riding in a 20 drop sudden rain shower. 24 hours later it worked again and has never failed again????
WLDWST
Milwaukee Eight (M8)
Jun 2, 2017 11:45 AM
Pat1963
Electrical/Lighting/Alarm
Apr 22, 2017 09:37 PM
2mOOn
May 14, 2013 07:06 PM
Tx2CaHD
Sep 27, 2008 09:19 AM
FLWanderer
Aug 28, 2006 11:55 AM
