Cleaning engine fins and base of cylinders
Old Apr 6, 2013 | 11:53 PM
bobgv's Avatar
bobgv
Pig Spit!
Old Apr 9, 2013 | 01:46 PM
blackflame's Avatar
blackflame
Originally Posted by 2black1s
Most of the previous responses are great if the question was how to clean the engine. But the question was how to remove "oxidation" from the edges of the fins without messing up the black.
Here's what I suggest as it works for me...
Get a pair of thin cotton industrial gloves. An old t-shirt will suffice if you don't have the gloves available but the gloves do make it a lot easier. Take some metal/aluminum polish and rub it into the gloves. Imagine rubbing hand lotion on your hands. The more polish you use, the more cross contamination to the black, so be judicious in the amout of polish. Then keeping your hand as flat as possible rub the edges of the fins to remove the oxidation and shine them up a bit. Use a cloth wrapped tightly around a paint stir stick, or something similar, the get into the areas your hand/fingers can't reach. Buff with a clean glove or cloth. Clean any excess polish off the black with mineral spirits. Follow with S100 Engine Brightener.
Ummm yep, i'll give that a try..
Old Apr 9, 2013 | 01:58 PM
rockajet1's Avatar
rockajet1
Default S100
Originally Posted by Glockmeister
I love the S100 products, spray on, give it ten seconds and wash off...easy. The engine cleaner, bike wash, and polish all work great. If you have a tough issue, take a tooth brush and hit it with a little effort, and it usually works fine...then wash like normal.
Old Apr 9, 2013 | 03:56 PM
Rickr01's Avatar
Rickr01
I didn't know S-100 made an engine cleaner? I use the engine brightner and like the results. Where do you find the engine cleaner, or are you just referring to the Standard S-100 general cleaner?
rquest
Sep 27, 2017 12:09 PM
smrthomer
May 12, 2009 07:46 PM
FLTR2008TRIKE
Oct 12, 2008 08:31 AM
MR. SCOOTINN
Detailing
Aug 1, 2007 04:22 PM
Reddawg
Detailing
Jan 4, 2006 05:12 PM
