Fork seals
Old Apr 8, 2013 | 08:31 AM
Stew Pidaso's Avatar
Stew Pidaso
If you have the Mono tubes just drain the oil and take your ride. If they are leaking you probably have more oil in there than is needed for lube anyway. Most that I have read here don't use much oil with the mono tubes. Fix the stanchions when you get back. Sand down the gouges with fine emery paper and replace seals. The stanchions are pretty hard steel so they shouldn't be so deep that you remove enough material that new seals would leak.
josh2002-ws6
Jun 2, 2016 11:19 PM
FL-kruzen
Nov 23, 2012 07:38 AM
rbb469
May 15, 2012 09:13 AM
vladt
May 25, 2010 04:22 AM
HDV-GLIDE
Jan 9, 2010 03:29 PM
