FLHX Suspension?
Old Apr 10, 2013 | 11:11 AM
fordhd2005's Avatar
fordhd2005
I changed the oil in mine (rear shocks) to synthetic transmission fluid and took off the air crap and installed a schrader valve in each one. I use the fancy Harley air pump and filled each one to about 20psi when riding 2up. Been riding it like that for a year now with no complaints.
Old Apr 10, 2013 | 11:20 AM
ultradouglas's Avatar
ultradouglas
Stage II
I am a big boy (300lbs) and a 150 lbs passenger, 2007 FLHX w tour box and bags full most of the time, with 440s and I have no problems. I like them way better than stock.
Old Apr 10, 2013 | 11:43 AM
Deer Stalker's Avatar
Deer Stalker
I've tried stock on Ultras and now have the hand adjustable premium ride HD shocks on my SG - much improved
Old Apr 10, 2013 | 12:11 PM
MidnightRider112's Avatar
MidnightRider112
I agree about the stock shock sucking. Took them off and put on progressive 444's. Got the 12.5" HD version. They ride great!
I used to hit a random bump or pothole and would hear my wife cussing behind me. Now she doesn't cuss.
Old Apr 10, 2013 | 02:30 PM
tj316's Avatar
tj316
call Howard at motorcycle metals , he has shocks is various price ranges that will fit your budget and be built to your specs
Old Apr 10, 2013 | 04:26 PM
chgofirefighter's Avatar
chgofirefighter
tried to PM you but I couldn't... Since I'm a rookie when it comes to doing DIY on my Harley. Any detail step by step instruction as to how I can get this achieved?
Thanks~ Pm if you wish...
Old Apr 10, 2013 | 04:49 PM
stupid_rope's Avatar
stupid_rope
remove the brass fitting and turn the shock upside down. then pump it manually.
i used a syringe to refil it...its a painstakingly slow process fyi
Old Apr 10, 2013 | 04:56 PM
citytrucker26's Avatar
citytrucker26
https://www.hdforums.com/forum/touri...ur-shocks.html
I did this method for draining. it is a mess fireaxe... Another easy way I found it mount the shocks upside down. hook up air lines. leave one air line not in all the way. pump air into it.. the oil comes spewing out... didn't have to pump much really.. it kinda siphoned itself out! once it starts dripping, it keeps going! Gary
Old Apr 10, 2013 | 05:00 PM
citytrucker26
I used IV tubing to refill mine.. took 2 days, had to keep unhooking line to burb air out. but it worked!
Old Apr 11, 2013 | 06:57 AM
fordhd2005's Avatar
fordhd2005
I didn't get a PM but everyone since has covered it. It's a pita to get the old oil out so just be patient and catch it in a container so you can measure what came out. The only thing I did different was use a clear plastic ketchup bottle from walmart (the kind you might see on a table at restaurant) to fill them back up with the same amount that came out.
