Wake UP 103
Old Apr 13, 2013 | 07:41 AM
leeway1275's Avatar
leeway1275
1st Gear
Default Wake UP 103
OK so not sure how folks feel about the 103 engine. I have a 2012 Street Glide which I love the ride, but not much for the power side of things. I'm looking to do some mods just not sure which to do for the money. Vanes and hines fuel pack will that help is a screamin eagle better with a big sucker air cleaner . I have Bassani slip ons now I just wondering if any tip tricks or just plan *** help for my 103......
Old Apr 13, 2013 | 08:03 AM
jg4660's Avatar
jg4660
Call FuelMoto.....
Old Apr 13, 2013 | 08:06 AM
K Melancon's Avatar
K Melancon
When I got my 2011 I thought the same thing. Then I put a Stag 1 with V&H Power Duals, V&H Monster Ovals, SE breather w/backing plate and SERT. I knew it would only give me a lil more torque, HP and wasn't expecting much more performance. When I took my first ride I cound not believe how much more power it gained. It really felt like it could not get out of its own way and very sluggish before and now I have power to spare. I say sluggish and I'm not a hot rodder so I know it was a slug.
Old Apr 13, 2013 | 08:10 AM
crimson13's Avatar
crimson13
I have a 2013 steet glide I did a stage 1 also, Dragos True duals, power vision and S&S stealth intake, woke mine up quite a bit
Old Apr 13, 2013 | 08:39 AM
gunnerchevy's Avatar
gunnerchevy
10 sg. 107. Bub true duals. Tuner. Screaming eagal breather.
Old Apr 13, 2013 | 08:46 AM
heritageblue2013's Avatar
heritageblue2013
If you had a 110 CVO I'll be you would want to wake that up too? Hummmmm. Guess we all want bigger and badass, lol I suggest a Boss Hoss with a V8, then after you own it a bit you'll want to wake that up!
Old Apr 13, 2013 | 09:28 AM
TeamMudd's Avatar
TeamMudd
my 103 totes my Ultra like my 96 did my street bob with slip ons, big air, and SERT.....
i noticed a bit more pick up with putting a Road Glide pipe with the end baffle cut out (seat of the pants dyno of course)!
you can wake it up with anything as much as you want with as deep as your pockets are.....
Old Apr 13, 2013 | 09:51 AM
basselope's Avatar
basselope
Setup is in my signature.
I can't compare it to other makers or to using Vieds, but I'm very happy with the results... bike doesn't feel like its towing a piano anymore.
Old Apr 13, 2013 | 10:03 AM
RPS1981's Avatar
RPS1981
The 103 arrives from the factory pretty choked, thank you EPA. Get some air in and out, add fuel to match the increased airflow, and she'll run pretty good.
0ldhippie's Avatar
0ldhippie
Along with your Bassani slip ons, try an A/C (Fuelmoto/Ness/SE) and tuner (PV/SEPST/TTS/PCV) with proper dyno tune. If that doesn't do it for ya add a cam like Andrews 57. After that the sky's the limit....
