So many folks have done this w/o issues, the problem is with the parts, your bike (e. g. ) damage to the forks), or poor installation.
I did mine a couple of years ago and started a thread about it--I son't recall anything about having to drill anything. I do recall buying a chrome banjo bolt used on the CVO master cylinder.
hey not sure if this helps but I encountered this problem when I put a 21 inch wheel on my sg.Same deal caliper pushed rotor, spongy lever.my advice is loosen the wheel and caliper,not sloppy loose.Spin the wheel hard a few times and lock up the brake.do this a fe w times and on the last time hold the brake and tighten everything back up starting with the wheel.1 other question did u mess with the triples at all? good luck
