How’s your 107 doing?
Old Apr 15, 2013 | 06:18 AM
HDV-GLIDE's Avatar
HDV-GLIDE
Originally Posted by groovna
I just had the Fuelmoto 107 Hellraiser build done on my Rocker (go pick it up Tuesday) and I to felt the same way and had the crank done.
They had your bike on their Facebook page....showed it stripped down and then the dyno run chart....Looks good...
Old Apr 15, 2013 | 08:10 AM
equandt's Avatar
equandt
The FM107 in my Ultra is awesome. It's a tw-555 build with no head work. No issues with heat. I've got about 1 year and 6,000 miles on mine. Pulls like a freight train off idle and as long as I dare stay on the throttle. 106 hp / 121 tq
Trying to figure out which 107 kit to pu in my RGC now.
Old Apr 15, 2013 | 09:31 AM
Proaction14's Avatar
Proaction14
Originally Posted by lionsm13
Would love to do a 107, just can't justify the $3K right now for the Hell Raiser kit, as I would not do the 107 w/out dong the crank work too, which is the weak link in the scheme of things as far as I'm concerned.
Uh oh, my next upgrade was going to be the Fuel Moto 107. I didnt realize doing a 107 without doing crank upgrades was even an issue. What issues are happening with the 107 kits and running stock cranks? I thought $2k for a complete 107 install was too good to be true!!!!!!
Everyone I know that has done a 107 has been lucky so far, I guess.
Ive seen certain situations where other failures with lifters, cams, etc, caused debris to take out the crank bearings. And a few situations where oil problems wiped out the crank bearings, but not particularly anything with the 107 kit causing stock crank issues.
Old Apr 15, 2013 | 10:20 AM
senna's Avatar
senna
Doing crank work is a "piece of mind " kind of thing. If you do not ring all the power out of your 107 every now and then, i.e. burn a little rubber or race a buddy or stranger then you probably are fine without crank work.
Old Apr 15, 2013 | 10:22 AM
soft 02's Avatar
soft 02
Wait till these guys with 107's get aroung 70k on them. Crank and rods definatly weak link. If you dont ride much dont worry about the crank.
Old Apr 15, 2013 | 10:54 AM
dbell66253's Avatar
dbell66253
I have a Rev Performance 107 haven't been able to ride a lot, just over 8k since the work was done last year around this time, but it's holding up well. I had one issue related to the heads was taken care of, my crank trued and welded with the timken conversion so I don't think I should have any issues there.
Old Apr 15, 2013 | 10:56 AM
equandt's Avatar
equandt
I'd like to hear from anyone that has torn up their crank from a 107 kit. I hear internet ghost stories about the crank being weak. I've never actually heard anyone say "my crank broke".
If you're building a touring bike, there is no reason to worry about the crank with a 107 kit. If you are building a +120 HP twin cam drag bike and are bringing it out of the hole at +5000 rpm, maybe you might want to think about welding up the crank...but then again you're also probably doing a lot of other work too.
My guess is that 90% of the 107s out there don't have the crank welded and trued. I don't view that as lucky, I view it that the 107s are a reliable upgrade.
No problems with my Ultra. I use it as a touring bike. The 121 tq my 107 kit makes is nice out on the road passing big trucks (or whatever else I want to pass). No crank work on mine; however I did upgrade to the SE clutch spring per FM's recommendation.
Old Apr 15, 2013 | 12:06 PM
Varooom's Avatar
Varooom
About 7000 miles on my FM 107, no crank work. I ride it pretty hard some times with no problems yet. I am going to put a SE cam plate and oil pump in it next week. I had .002 runout when I did the 107 build and checked it. I am very curious to see if runout changed?!?!!?.
That will tell the story.
Old Apr 15, 2013 | 12:26 PM
soft 02's Avatar
soft 02
The crank is a bad design with loose tolorances. The rods also have a pis poor design at the small end. This is why the changed the design in 2010 and up models. I wouldn't trust a 07-09 to last 100k. No internet rumor just my opinion about these specific years going 100k with no issues. Wait a few years for this issue to present itself. At 118k my 96 went out. HD took a step backwards when they stopped doing the Timken bearing and forged flywheels and when they tapered the rods in 07 they became even weaker. Sure if your only putting a few k a year its not a problem but start putting some big miles on these motors and you will see more issues. And with the average pinion shaft being .003 sure thats fine for a while but it ends up beating up the bushing in the cam plate and putting early wear on the oil pump gyrotors. Im not making this stuff up. Look at the design and compare it to an 03 or 02. They are making these motors for ease of assembly and cost. Truth is most will never see an issue and sell it before its a problem.
Old Apr 15, 2013 | 01:23 PM
stupid_rope's Avatar
stupid_rope
i'm running a 106 with no bottom end work. ill let you know when the crank goes...but im not too worried about it
