Boom audio
Old Apr 19, 2013 | 01:15 PM
UltraNutZ's Avatar
UltraNutZ
Originally Posted by royston
Hi Guys
I may have a chance to pick up some used speakers economically and whilst they may not be the best, im wondrin if they will be ok, they are Harley boom audio speakers Part No: 77181-01 any ideas if these would fit the stock system on an 2011 FLHX and if they might be an improvement?
Cheers
R
They'll physically fit perfectly but I wouldn't do it. These are 8 ohm speakers and your head unit is designed to work with 2 ohm speakers. You'll effectively cut your total volume output by more than 1/2.
If you're wanting to replace stock speakers with something good and not real expensive, check out the Polk Audio MM651 speakers. Going to a 6.5" speaker will require a set of adapter rings from DragonFly or someone else but it's a drastic improvement over stock and well worth the cost.
Old Apr 19, 2013 | 01:29 PM
UltraNutZ's Avatar
UltraNutZ
Originally Posted by luc.who
I agree they are better than stock, I have them and running them with an amp right now. I am planning to replace mine in the next few months with 6.5 inch.
If I were doing to replace the stockers again, I would look at the 6.5 inch polks. I think they are db651s.
MM651s for stock replacement as they are 2 ohm. the DB651s are 4 ohm. you want to match components as closely as possible when doing audio setups.
Old Apr 19, 2013 | 01:45 PM
claytucc3's Avatar
claytucc3
Originally Posted by mmats69
I have the boom audio with the amp. No problems hearing it at any speed. There are times when I have to turn it down.
Mmats, did you install the speakers and the amp at the same time? If not did you notice a major difference with the amp?
bob 103
Mar 3, 2017 01:15 AM
wilcoxracing
Feb 28, 2017 01:11 AM
gordy67
Audio Systems
Mar 20, 2016 03:36 AM
BrownSanta
Touring Parts
Jan 20, 2013 10:30 PM
Arizaino
Screamin Eagle CVO Models
Dec 8, 2012 11:02 AM
