abs light flash,with new wheels
Old Apr 25, 2013 | 07:12 AM
skratch's Avatar
skratch
Originally Posted by Recycled
I don't know what you have done regarding wheels & tires, but for example, if you have a larger front wheel/tire circumference, the wheel will rotate slower and the speed is read by the wheel speed sensor. I may be wrong because of your bike being an '08 but that's how my '07 tone ring ABS works. Just by replacing the rear with a 1/2" shorter tire and replacing the front with a 1" taller tire I got a constant flashing ABS light. I will be interested to see what you find after reading the ABS fault codes. Good Luck!
i think your abs is different than the newer abs systems. i just put an 18'' wheel on the rear, and the even though the rear tire is a low profile tire, it is still about .60 inches taller overall diameter it is not showing any codes or flashing the abs light.
sfcmo357
Milwaukee Eight (M8)
Jun 29, 2017 02:41 PM
RedBike08
Wheels/Tires
Aug 8, 2014 10:26 AM
smyffa
Nov 16, 2013 08:51 AM
UPSGUY
Wheels/Tires
Oct 25, 2010 07:58 PM
keepertx
Apr 10, 2010 10:30 PM
