abs light flash,with new wheels
Old Apr 19, 2013 | 10:09 AM
outlaw bagger's Avatar
outlaw bagger
Default abs light flash,with new wheels
so I just got my new tires and wheels, for my 08 , after installing them I rode to work and the abs light wont stop flashing, the wheels, have abs bearings and they are on the correct side....
Old Apr 19, 2013 | 10:13 AM
senna's Avatar
senna
Is the seal that faces out on the ABS bearing green or Orange? May be they put the bearing in the opposite of what it should be?
Old Apr 19, 2013 | 10:19 AM
outlaw bagger
ill have to check,, im color blind,,,lol ill recruit some help
Old Apr 19, 2013 | 10:22 AM
outlaw bagger
is there a way to tell witch wheel is throwing the code?
Old Apr 19, 2013 | 11:11 AM
outlaw bagger
they look to be green side out ....
Old Apr 19, 2013 | 11:15 AM
Recycled's Avatar
Recycled
Did either of the wheel/tire overall circumferences change? If so, that's your problem. The ABS controller will set a code if it sees a change in wheel speed outside of the acceptable parameters. New wheel/tires would do just that if the rotational speeds ratio difference from front to back is different from stock.
Old Apr 19, 2013 | 11:20 AM
senna's Avatar
senna
I just put a 21 pm mine and have no abs issues.
Old Apr 19, 2013 | 11:23 AM
outlaw bagger
I don't understand how it would know what the outside diam. would be as the sensor is at the bearing .....
stupid_rope's Avatar
stupid_rope
pull the maxi fuse, let the computer reset, and then check again.
i will warn you, the abs sensor is fairly fragile. i have ****ed up one before
Old Apr 19, 2013 | 11:39 AM
Recycled's Avatar
Recycled
I don't know what you have done regarding wheels & tires, but for example, if you have a larger front wheel/tire circumference, the wheel will rotate slower and the speed is read by the wheel speed sensor. I may be wrong because of your bike being an '08 but that's how my '07 tone ring ABS works. Just by replacing the rear with a 1/2" shorter tire and replacing the front with a 1" taller tire I got a constant flashing ABS light. I will be interested to see what you find after reading the ABS fault codes. Good Luck!
