Another monoshock ? I know
Old Apr 22, 2013 | 09:00 PM
The Q's Avatar
The Q
Reading through this forum when researching the lowering Monotubes it seems Progressive recommended 2 clips for a less harsh ride. I have no complaints at all about the ride with 1" lower and 2 clips. I figured I'd try the 2 clips first and if it was to soft I could pull it back apart and add a clip. I'm glad I did it this way first instead of installing 3 and having to go back and remove a clip.
Old Apr 22, 2013 | 09:36 PM
senna's Avatar
senna
1" lowered is still 1/2" over stock, which, on a street glide is now 1 1/2" higher compared to the rear. I lowered mine 2", now I am 1/2" over the rear. I really like how mine rides, the stock rear does suck, the front is very smooth. The bigger wheel does roll down the road better than the smaller 17"/18" wheel.
There is some members who have used 2 clips but the use the other bottoming spring to end up at 1 1/2" lowered, now back at stock height.
The mono tubes come with 3 clips per side and two different bottoming springs.
2" lowered is no clips and both spings
1" lowered is two clips and one of the springs, correct?
Old Apr 26, 2013 | 05:10 PM
nthere1's Avatar
nthere1
I just got the shocks today, they were on the porch when I got home for work. Going to ride this weekend start on it next week..
Will read the directions and this site this weekend and get ready for the project.. If I get stumped will yell back..One question what oil i know there is alot of opinions on here and alot diferrent types just confused..195 lbs the other half is 150...I guess synthetic oil ....Is there a sticky note on fork oil like there is on motor oil..
Old Apr 26, 2013 | 05:27 PM
NMNSG08's Avatar
NMNSG08
I went with 3 clips,and love the ride.
senna's Avatar
senna
You are putting mono tubes correct? The oil is just to lube the bushings on the slider, has no effect on dampening. you will only use 5 oz. in each leg, I think the call for 7 or 10 wt.
Old Apr 26, 2013 | 07:36 PM
nthere1's Avatar
nthere1
Thanks, my addhd kick in. I do remember reading that on the forum. Yes I am installing the mono. I do except tricks and tips
Village Idiot™
Mar 12, 2014 07:00 AM
rs87277
Sep 25, 2012 04:10 PM
yoyoman05
Aug 6, 2011 05:41 PM
CLL375
Jul 6, 2010 09:25 PM
UPSGUY
Jul 26, 2009 10:05 PM
