Hidden Antenna?
Old Apr 24, 2013 | 02:21 AM
crimson13's Avatar
crimson13
I tried the ebay hidden antenna unfortunatly it did not work well for me, I am going to try this mod ,
https://www.hdforums.com/forum/touri...-st-glide.html
Old Apr 24, 2013 | 09:05 AM
Frank Dukes's Avatar
Frank Dukes
Originally Posted by bberck
On my SG I unbolted the antennae bracket and strapped it to the saddle bag support. I then ran the stock antennae up the support and along the frame with the wires.
Seems to work as good as before and only cost a few wire ties and a plug for the hole.
gonna give this method a go after work today. i like my radio and dont wanna lose reception.
Old Apr 24, 2013 | 10:05 AM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
^^^^^^^^^^^ What bberk said. Works great.
Old Apr 24, 2013 | 11:09 AM
gmc's Avatar
gmc
I used power antena fr. Pep Boys but when I put a y splitter and used it in conjuction with the original antena wire wraped under my seat it worked the best. Burn yourself a mp3 cd using the data option and you can get 120-150 songs on it.
Old Apr 25, 2013 | 07:03 AM
Frank Dukes
Well that was easy.. worked like a charm. took off seat, bag and side cover and routed it under and thru. took off antenna, removed mount and remounted almost horizontally using only one of the bolts on the the bracket using loctite to make sure it stays. then route antenna up thru where the wires go theres a nice little hole i was able to squeeze the antenna thru. only took one zip tie to hold it down to frame. i did have to cut about 3 or 4 inches off the tip to make it fit a little easier. i could have made it work as is but was comfortable losing a little bit of antenna without much worry. just gotta hunt down one of those plugs now.
good stuff.
Old Apr 25, 2013 | 07:09 AM
drumster's Avatar
drumster
I have this one
http://www.ecshylites.com/catalog/it...191/721930.htm
It's a bit big and placement under the fairing is tough but it does fit. Works well.
Old Apr 25, 2013 | 07:12 AM
bberck's Avatar
bberck
good stuff.
I was surprised but plug was only a couple dollars at dealer and they had it in stock
Old Apr 25, 2013 | 10:10 AM
Baffler1's Avatar
Baffler1
nice to know - Thanks
Old Apr 25, 2013 | 10:36 AM
myfhfb06's Avatar
myfhfb06
https://www.hdforums.com/forum/touring-models/680634-my-free-hidden-street-glide-antenna.html
Try this. Works great for me!
Old Apr 25, 2013 | 11:03 AM
Fuimus1314's Avatar
Fuimus1314
I just got this one also. Seems to work fine and it's only $25.
