Looks... in general duals produce slightly less power. The V Twin likes some back pressue so a 2-1 pipe is best and 2-1-2(like the factory) is next and duals last. Biggest first improvement is to get rid of the cat in your pipe either by removing it from stock pipes or replacing the pipes
Mostly looks and sound. On the newer bikes ya get rid of the heat off the CAT. Someone just had a dyno run where they only got 1hp with trueduals over stock on a new bike?
True duals look and sound better, no doubt on that. The difference in power is correct but at the level you're at, it's a couple hp. What you should be focusing on is Mid-range Tq, it is a little more with a 2-1.
A bike that makes 80hp with true duals might make 82hp with the right 2-1. is that worth it to? That's up to you.
Yes. The factory 2-1-2 and earlier 'Y'pipe exhausts are pretty lousy so anything you put on that flows better is an improvement that you will feel. And that includes true duals since the factory smashes the '09 and later cross-under pipe for ground clearance.
Only on internally modified motors does a 2-1 start to out-perform a stepped header true dual. For any Stage-1 mods a true dual will be the same, or at least pretty dang close to any 2-1.
I had my cat removed. To do it right you have to cut the head pipe in half, clean out the mesh, then get it welded back together. I've heard the weld job can be cheap ($30-50).
I took the easy way. You can buy stock headers with the cat already removed from ebay for about $150. When it arrives, just swap headers. Make sure the pipe you get was truly cut in half and not some 'drilled out' or a little window cut out.
After market Cross pipes range in the $350-500 range so the ebay option saved me quite a few bucks.
