New cams
I been reading and searching for awhile. Looking for more info on drop in cams for my 2006 classic. Thinking about the crane htc 300-2 with a +4* gear or a andrews 21. anyone know where i can find some dyno sheets or more info.
The bike is stock except for se/ac and slip-ons.
Thanks
Thanks
You need to know what you are planning. Not Just a cam. Cams are a Give and Take.
IF you just do a low torque cam, USUALLY look for a cam with Earlier Intake Closing.
IF you stock cam closes at 30* then a lesser number WILL get you more compression and that is POWER. Low end Torque. Lower RPM to achieve.
Just an example here is the SE255 on my bike, Intake closes at 25*. That is 5* sooner then the stock cam in my bike. That means it is going to HOLD and GET More compression into the cylinder= POWER
IF the cam I choose has an intake that closes at 40* and my stock one closes at 30*, that 40* cam NEEDS other things to replace the low compression it will have with intake valve closing Later.
so there is the GIVE and TAKE...
It does involve More than the intake valve close BUT Intake Close is a good INDICATOR to use When Only wanting to do a CAM.
Big Cams need More Compression to Off-set their losses. Head work,high compression pistons,flow/port, larger valves etc.......
Cams that will do good in a STOCK bike Mostly have Lesser = earlier closing intake numbers to do Just cams.
IF you want to do High RPM always and don't care about com'n on Early for the low end torque, then you have some Leeway using a cam with later intake closing. BUT NOT Much with out Increasing the Compression.
IF 30* is stock, I'd not go more than max 36* better would be 34*..
Motors run GREAT keeping the ccc 180 at sea level... anything Higher need Other stuff.
Now that is my take here.
signed....REDHEAD
Thanks
But, here is my Dyno sheet for my 2002 FLHTCUI
SE 203 Cams, 95 inch ,flat top pistons and S&S SPO Mufflers
SE/K&N air filter with a SE 6Spd gear set (which has nothing to do with your ride)
I use a SEPRT and tuned by Russel at Lonewolf in Nanaimo BC.
I ride two-up 25 % of the time and commute to and from work.
My fuel mileage after the tune is around 42-44 MPG if I have done my math correctly.
Rob
signed....REDHEAD
Wow very good info... thank you
