Floating Rotors?????
Old Feb 19, 2007 | 10:26 PM
Rodman813's Avatar
Rodman813
Default Floating Rotors?????
I'm thinking about getting some awesome wheels from HOGPRO. The rotors aren't floating. Polished SS!!!! My 06 SG does squeal with stock setup....if I just replace the rotors w/ these non floating rotors, will the squeal still be there????
Old Feb 19, 2007 | 10:33 PM
Abnmarine's Avatar
Abnmarine
Default RE: Floating Rotors?????
Get you a set of Lyndall "Z" brake pads. The noise will be gone and also the brake dust.
Old Feb 19, 2007 | 11:40 PM
tgaetto's Avatar
tgaetto
There is also a service bulletin out there it says to swap the right and the left. I had it done at the 1k (practically had to beg!). Typical service expectation unless your spending a crap load they don't want to do anything... I think it was a stock wheel/rotor engineering thing wont be a problem on the HP's
By the way.... Ab your wheels look sweet!
[/align]
Old Feb 19, 2007 | 11:53 PM
Abnmarine's Avatar
Abnmarine
ORIGINAL: tgaetto
[/align]
Thanks. I owe it all to BountyHunter and Discover.
Old Feb 20, 2007 | 12:26 AM
JPstreetglide's Avatar
JPstreetglide
I also had a constant noise in front brakes. Tried switching left to right rotors and noise went to other side. Went with floating rotors and noise went away. Must have been a defective rotor but HD did not warranty it. THey said that brake components are not warranteed
Old Feb 20, 2007 | 08:05 PM
Primo's Avatar
Primo
ORIGINAL: Rodman813
My wheels and non-floating wheels are from HogPro as well. I had the floaters on from day 1 and was concerned about this issue as well.
Got my custom wheels and rotors installed and.................. no squealing.
Worry not Rodman. I think you'll be ok.
Primo
tjdlsj
Dec 13, 2012 07:24 PM
streetglide82
Apr 6, 2012 09:40 PM
bobby5
Sep 29, 2010 03:18 PM
sparky_mo
Feb 24, 2009 03:18 PM
TheBreeze521
May 4, 2007 01:50 AM
