6 piston front brakes
Old May 5, 2013 | 11:03 PM
texas ultra's Avatar
texas ultra
6th Gear
Default 6 piston front brakes
I have noticed this trend toward one sided 6 piston calipers on many custom bikes. Do these calipers have equal clamping/ stopping force to say a stock twin brembo front set-up? I will be updating to a custom front wheel and would like to go with the one sided look, but I am not willing to give up braking ability.
Thanks for any input.
Old May 5, 2013 | 11:20 PM
bklynbob's Avatar
bklynbob
You generally measure swept area, a larger disc w/ the six piston is less but adequate. As in all mods, everything is a compromise .
Old May 6, 2013 | 10:16 AM
Harleypingman's Avatar
Harleypingman
Hydraulic pressure from the m/c is also a factor in braking power.
Carl
Old May 6, 2013 | 12:25 PM
Pitbull2411's Avatar
Pitbull2411
Carl
+1 and I think Ness is making a set up with twin calipers on one side.
Old May 6, 2013 | 04:28 PM
sgdiesel's Avatar
sgdiesel
There are 4 variables that govern braking effort in hydraulic disk brakes...
1. Total area of the pistons
2. The hydraulic pressure in the system
3. The diameter of the disks / rotors
4. The number of disks.
Your initial question only asks about number of pistons in the calliper and reducing to a single, so the simple answer is:
Assuming hydraulic pressure remains the same (ie you are using the same master cylinder and pulling just as hard on the lever) AND the rotor diameter (for now assume the pitch centre of the brake pads) stays the same then to get the same braking effort...
Total cross sectional area of the 6 pistons of the single calliper must equal Total cross sectional area of 8 pistons (ie 4 pistons per calliper - 2 callipers).
Of course this gives you equal braking effort but NOT equal heat dissipation ability, which is also important when comparing overall brake performance.
If, for example, the total cross sectional area of 6 pistons is only half (chosen to keep the maths imple) and you still want the same braking effort then you have 2 choices:
1. You an double the pressure (which is achieved by a different ratio master cylinder)
2. You can double the diameter of the rotor
Of course by calculating carefully and matching things up, you can also achieve the same braking effort by increasing pressure and rotor diameter
Again, to stress, this does not apply to heat dissipation, so aggressive and prolonged braking - for example on a long twisty section - could lead to a very serious degradation in brake performance.
Old May 6, 2013 | 04:33 PM
NMNSG08's Avatar
NMNSG08
I have a 21"wheel up front and a 13" rotor with a 6 piston jay brake caliper,and my bike stops just fine.I am an aggressive rider and i have no issues with the single sided set up.
Old May 6, 2013 | 04:57 PM
grbrown's Avatar
grbrown
I have twin 6-pot Harrison calipers, with 13" full floating rotors. Can't see why anyone would want to ride with less!
Bobbycaz
Jul 21, 2018 12:19 PM
Jswerve
Nov 2, 2012 02:45 PM
Shinwacker
Aug 5, 2010 08:07 AM
mjunk1
EVO
11
Sep 5, 2008 03:24 PM
Warpig
Aug 9, 2006 09:55 AM
