HDPDplus 2 Questions
Old Apr 13, 2014 | 04:11 AM
Lucky1.63's Avatar
Lucky1.63
Originally Posted by bikerbehaviorist
Do any of you have experience using this device with lightning based ipod or iPhone and an adapter - does it work??
I've been thinking about purchasing the HDDPlus2 for this same application. I emailed Iron Cross Audio they told me it works fine with the Lightning Adapter with an iPhone 5. It's now on the list for procurement......
Old Apr 14, 2014 | 08:41 AM
murph's Avatar
murph
An up date with the cables. I was putting my ipod inside of my saddlebags with the wire just coming out of the top and closing the lid. Well, after time I have noticed my speakers were shutting off. Mostly the right side. Thought my MM651s were going bad again... Well, it comes out it is my wire being pinched between the lid and saddle bag. I should have known better. I will be cutting out a notch with a grommet now. I had to order a new wire. Just some info for everyone.
Old Apr 14, 2014 | 08:53 AM
camsmith's Avatar
camsmith
This'll work...
Old Apr 15, 2014 | 08:30 AM
murph's Avatar
murph
Originally Posted by camsmith
Thanks. That was exactly what I was going to do. I have two wire though. I have a power wire to charge my phone which is in my saddle bag.
Old Apr 15, 2014 | 08:52 AM
bigdady's Avatar
bigdady
I have the iphone 5s and use the lighting adapter is no problem
Andy
Old Apr 19, 2014 | 02:18 PM
major105bc's Avatar
major105bc
Does the iPod shuffle function work with the HDPD Plus 2?
Thanks.
Old Apr 20, 2014 | 09:01 AM
bigdady's Avatar
bigdady
Yep everything works and works well
Thanks.
Old Apr 22, 2014 | 07:00 AM
murph's Avatar
murph
Thanks.
Yes it will. I have an ipod classic. I had to change out the hard drive with a SD card. Hard drive was crashing from the vibration. Now, no hard drive. It was a pain taking the ipod apart, but well worth the trouble.
Old Apr 22, 2014 | 07:52 AM
sfckelley's Avatar
sfckelley
I have an HDPDPlus installed and using a lightning adapter for both my iPhone 5S and ipod. I have not had an issue with either, even charges them to boot!
Old Apr 22, 2014 | 08:13 AM
frankiefire702's Avatar
frankiefire702
I got my HDDPlus2 last christmas and it came with a 3 ft cable so I ordered the extension cable at the same time. I ended up not using the extension and mounted my ipod under my fairing. I have the extension if anyone needs one in the touring for sale section.
