I need to slow down
Old May 7, 2013 | 06:50 AM
Sam2010's Avatar
Sam2010
The power vision will let you adjust it also.
Old May 7, 2013 | 07:00 AM
jeffreydsilver's Avatar
jeffreydsilver
Default On The Money
Originally Posted by lh4x4
Anytime that I have passed those small radar trailers near construction sites and other areas all of my HD's have been spot on.
dan conner's Avatar
dan conner
so it would be best to get the old slide rule out, measure your tire diameter, get your final drive ratio, and take you r.p.m. and accurately compute your true speed?
all you really need to know is that your cruise does not work above 90 m.p.h.. as long as your cruise is working--you are not going too fast! next question.
Old May 7, 2013 | 07:07 AM
skratch's Avatar
skratch
Originally Posted by cass
lots of folks are off by just a little. mine, when i go 65 on the spedo is reading 61or so on the gps. makes you reach your mileage warranty a lot sooner. i asked if they can adjust them and my service guys just said nope. i think its all a plot by harley :-).
what mileage warranty?
Originally Posted by Charlie Fogg
My bike's speedo indicates I am going 2mph faster than my GPS says I am going. If speedo says 70, GPS says 68. This is true at all speeds as far as I know.
the way i understand it is that the gov will allow speedo to read higher than actual, but can not read lower.
Old May 7, 2013 | 07:21 AM
OldArmy's Avatar
OldArmy
Seems like every car and bike I've ever had read higher than the actual speed. My current SG is a consistent 3 mph higher than actual speed but, so was my last one and so is my Jeep. Maybe the manufacturers are doing this on purpose to avoid liability for....?
Old May 7, 2013 | 08:01 AM
Lowcountry Joe's Avatar
Lowcountry Joe
It also contributes to the ridiculously high mile per gallon claims you read about on this forum.
Old May 7, 2013 | 08:20 AM
UUNetBill's Avatar
UUNetBill
I reprogrammed my ECM to engage EITMS at highway speeds. Now I have a 51.5 inch thumper that gets 85 mpg on the highway.
Just kidding, of course.
Old May 7, 2013 | 09:33 AM
mikelikesbikes's Avatar
mikelikesbikes
Your true speed can easily be checked using mile marker signs as they tend to be pretty accurate. My Zumo usually reads a couple MPH lower than my speedometer.
Old May 7, 2013 | 11:08 AM
glide2meetu's Avatar
glide2meetu
My speedo reads 5mph faster than what I am going according the radar signs that are put up, not that I trust those either.
Old May 7, 2013 | 11:27 AM
Kebo's Avatar
Kebo
Just to put some clarity on this discussion and coming from metric bikes, all of the metric bikes are off between actuall and speedo readings for speed. I was told way back when that this was done on purpose to fool people into thinking that they were going faster than they really were. Now I know Harley used to have a speedo that said it was "certified" in small writing somewhere on the face. My wife's Sporty that she had said this as well as many other older Harley's I have seen. Those speedo's were calibrated to be dead on, at least when they left the factory. If you look at all of the new bikes.......none of them say that now. I beleive Harley has subscribed to the same non-sense that the metric manufacturers do. Maybe it's a "gubment" enforcement thing.
