Backrest Question
Old May 7, 2013 | 09:12 AM
vtdiesel's Avatar
vtdiesel
Good info and good laughs, thanks!
Old May 7, 2013 | 09:37 AM
yowflhtk's Avatar
yowflhtk
Originally Posted by vtdiesel
Anybody ever installed an adjustable rider backrest with the integrated gas spring on a bike with mid frame air deflectors?
Just did it a couple of weeks ago. The instructions could have been a little better, but you should be able to figure it out. Drop me a note is you have any questions.
..................martin
Old May 7, 2013 | 02:03 PM
TheGrandPoohBah's Avatar
TheGrandPoohBah
Instructions are useless, just go for it.
I have RJ's Originals Heat Shields, lever is right behind it.
Can't see it, reach under on the road, it's right there.
No problem.
Old May 7, 2013 | 02:07 PM
vtdiesel's Avatar
vtdiesel
Sweet! Just bought it, thanks!
Old May 7, 2013 | 03:03 PM
Mike_M's Avatar
Mike_M
Yes, I have the adjustable rider's backrest.
Yes, I have mid-frame air deflectors.
Yes, I had the control hidden in behind.
Then I found that reaching down around the air deflector to adjust the backrest would put me too far away from the backrest to adjust it properly. Careful measuring, and some even more careful use of a dremel & thin cutoff wheel put the adjuster ON the left mid-frame air deflector. A little noticeable when at a stoplight, so I may shave the lever handle a little, but when feet on boards or highway pegs the lever is well out of the way.
Since the colors are black on black, it's not really noticeable unless you're looking.
Now I have better adjustment when riding, and can get the full range of adjustment out of the backrest.
Hedgehog
Mar 19, 2014 12:02 AM
WB
Jan 10, 2013 07:56 PM
crissguinn
Jul 13, 2012 08:58 AM
hogrider09
Jul 18, 2010 01:10 AM
fryeca
Aug 20, 2006 09:14 PM
